Good question. I have been running everything in AES mode with the region set to USA in order to recreate my childhoodAre you running games in MVS mode or AES mode when this happens?
I can't say. I have literally kept it on USA AES mode since I got the cart. It was the first option I had changed. I will change it later and see if I can get it to happen again. Do you think it has something to do with the region select or machine type?All clear. Does this happen also in another region or in MVS mode?
That number means that you have 240 folders in /game (don't count "menu") and from those 240 only 238 have a reconginzable game.I keep getting 238 out of 240. Is there an actual up to date list of directory names of what the cart is scanning? Current menu/firmware.
Not likely with the current design.Is cd support coming to the cart?
We looked into it and with our current design it would not be possible to do it in a quality way. There is no new revision planned.Thanks. Is there a hardware revision coming? I thought I read somewhere that they were working on CD support in a firmware?
Time for a "Pro" Version... Every one does it... PS pro, Switch Pro (Rumored), Everdrive Pro, Terra... Neo SD Pro (Those guys).We looked into it and with our current design it would not be possible to do it in a quality way. There is no new revision planned.
More the reason not to do it.Time for a "Pro" Version... Every one does it...
Get one of these (Assuming you have a POW3 (WSU090-3500-R TRIAD MAGNETICS) this will solve a lot of problems at least it did for me. Glitchs time to time but hitting the reset button usually fixes it. I have the same problem with the competition's cart as well. Official carts boot every time. I like to get Samurai V Perfect running. Still can't figure that one out.It would be a very good point to have CD support, terrific.
But I think that first it would be necessary to solve the serious problems that this cartridge has now in terms of voltage (in my case, same glitches happens with 2 different Darksoft cartridges in 3 different AES and with 3 different PSUs, including the one from retrogamesupply).
Just saying .....
