Sp33dFr34k
I forgot to mention, the garbled Unibios logo has also been fixed!
I've tested the new firmware/TOP file and all glitches are gonne (menu, unibios & in-game).I'll update the firmware in the 1st post. Probably a last minute introduced bug.
Thanks for your answer Darksoft,We will have a look at it whenever we can, but I see that you are playing the song #4 of the menu. As we mentioned a couple of times, the menu uses a very complex method to play mod files. The songs #3 and 4 have 8 channels IIRC and was making some sound problems when exiting the menu.
Can you try changing your default music in the menu to #0,#1 or #2 and see if the glitch dissapears?
you have unibios and then the cart is trying to force another region. Which one are you using on each?Hello,
Thanks for the update.
Flashed the latest firmware / top / menu following @SVM steps.
I have really weird issues.
mslugx in slot1 and kof98 in slot2.
I can boot mslugx, but I'm stuck on red warning screen when booting kof98.
So I check the system configuration: I'm in MVS / Europe.
Then if i go to kof98 game configuration, everything is in japanese.
I still have glithes with unibios 4.0 at first boot and sometimes I have glitches in the multi menu.
Not really important, but the monkey is still not in the foreground![]()
I'm not familiar with this game. Have you compare how it sounds in the original? Can you tell me a couple of examples in your video when it doesnt sound as it should?Whatever music selected in the music, same issues with musics always.
Also the garbled Unibios logo is not fixed (even with the last update of today). I still see a garbled Unibios on each boot.
Indeed, i have exact same issue if i do exactly you wrote.Hello,
Even though I don't really mind I thought I'd mention it since a few people reported it as an issue in this thread. Next to the fact that I can definitely appreciate the DS team spending their time on the small (imo) things as well
Yes everything is updated and the menu also. (BUFF deleted also before you askI'm not familiar with this game. Have you compare how it sounds in the original? Can you tell me a couple of examples in your video when it doesnt sound as it should?Whatever music selected in the music, same issues with musics always.
The Unibios logo is fixed (except the 1st time when you power on). Did you also update the menu?
)I have tested it on MVS mode on a 3.3 Unibios.KOF98 will only work in MVS mode, as the original is intended to.
I'm using Arcade / Europe for both.you have unibios and then the cart is trying to force another region. Which one are you using on each?Hello,
1st boot of unibios will not show the logo, but the rest will. This will remain like this.
We're currently looking at the glitches when navigating the menu.
so what do you mean here?I still have glithes with unibios 4.0 at first boot and sometimes I have glitches in the multi menu.
Even if KOF98 is the only game on slot 1 and no others games on others slot, the game is frozen with the WARNING message.I'm using Arcade / Europe for both.Strange, I have the logo at first boot.you have unibios and then the cart is trying to force another region. Which one are you using on each?1st boot of unibios will not show the logo, but the rest will. This will remain like this.Hello,
tell me the exact version and reviosion of firmware that you see in the menu. Please tell me also the date of the menu.Also i can confirm that the Unibios bios issue is really not fixed, i always get a glitched logo at each boot and reboot.
Firmware revision : 0x03e4tell me the exact version and reviosion of firmware that you see in the menu. Please tell me also the date of the menu.Also i can confirm that the Unibios bios issue is really not fixed, i always get a glitched logo at each boot and reboot.
I have vertical lines on unibios 4.0 logo when booting for the first time into the multi menu.so what do you mean here?I still have glithes with unibios 4.0 at first boot and sometimes I have glitches in the multi menu.
Same the glitched logo is only when return or launch the menu when starting the MVS.I have vertical lines on unibios 4.0 logo when booting for the first time into the multi menu.Not really a problem, because I have this since the beginning, but as it's mentioned it should have been fixed.so what do you mean here?I still have glithes with unibios 4.0 at first boot and sometimes I have glitches in the multi menu.
And in the menu, I have some horizontal lines which appear sometimes, and sometimes not.
