mathewbeall
Enlightened
@Darksoft - all good with the new 1205 flash/top you put up. I haven't tested a bunch of games yet, but all visual flicker is gone now...@Pinball, @SVM, @mathewbeall. Can you try the new top file published in the 1st post together with this flash.img attached and see if that fixes?
Also let me know which Firmware revision and build do you see in the menu when you go to "About". It should be right now 0x03e4 and 5603.
After you install this flash.img attached, it will be 0x0000 and 5603
Thanks!
