rockbottom
b16 Test failed
Try again, should be working now
b16 Test failed
b16 Test failedYep, there's a problem, i'm looking into it...
Try again, should be working now![]()
B13 = 00111@lydz - i picked up two of these in the hope of fixing my Magic Sword and Final Fight boards which I believe are failing due to the C board.
I can't get these to work. Am I doing something wrong?
According to your first post for Magic Sword (B13 on the C board), the DIP switch should be set as 54321 = 11000. I assume 678 dips don't matter to functionality? Regardless, when I try the C board with these DIP settings I get even worse graphical output than the stock C board.
Same issue with Final Fight. It goes from partially screwy graphics to total garbled graphics when I use your C board. See attached for example, the sprites are all just blocks with lines in them.
I bought one and I assume it works fine. I say I assume because I only tested it with my Street Fighter 2 World Warrior (B-17). Worked with no problem.Hi all,
How many users bought from this C board? Whoever bought it will tell you that it really works. I bought one, it didn't work. I paid for another shipment, got another c-board, arrived today, I tested it doesn't work. A friend also bought, does not work. Lydz doesn't answer. This is correct?
I wrote to taobao support for the first defective product. You will then be offered to refund the price (postage will not be refunded) or resend the product. I asked to be sent again because I need it. I asked the seller to send me a test video of exactly the product they will be sending me during operation. I got a video that shows it in action but I can’t say 100% that I got the same. When I arrived I took a video from the unpacking to the testing where it can be seen that the new card is not working either.
