diy cps1 c boards b-xx
I wrote to taobao support for the first defective product. You will then be offered to refund the price (postage will not be refunded) or resend the product. I asked to be sent again because I need it. I asked the seller to send me a test video of exactly the product they will be sending me during operation. I got a video that shows it in action but I can’t say 100% that I got the same. When I arrived I took a video from the unpacking to the testing where it can be seen that the new card is not working either.
https://drive.google.com/file/d/11kE25jpYITUKYLeyNgYJaYHoOh9yQOHz/view?usp=sharing
Is that possible the board is misaligned by one pin?
I watched as I put up the board. All pins are connected properly. I also measured the connections with a multimeter. No broken contact was found. I spent a lot of time with the first faulty panel to check everything. I measured the legs of the 21 chips, all the connections. No errors found. I can think of a fault with the programmed logic chip. It seems to me that the content is flawed. Or the switch is malfunctioning for some reason. It would be nice if lydz would make the content and chip programming available.
When selling a product, you also need to be prepared for possible mistakes. It is the duty of a seller to help buyers. he lives from them. I regret buying it. You may have used code made available by others. But it could help by making it available to us as well.
There's definitely a language barrier involved with lydz. Maybe @sheep_nova could help out?
Its not any language barrier sir, Lydz understand very well what everyone wrote here ☝️... i will ibtend to pay for this kind of C board just to see if will work with my Daimakaimura Resale game i have ✌️
It's a human barrier. I had issues with his S16 multi and he never resolved it; in the end resorting to an insulting and accusatory tone implying I fabricated the issue.
He has some interesting products but I wouldn't count on after sales support.
100% ... but @lydz , please sir , make a video with how to use this custom C xx Board ... or please guys, @suverman , @-Ace-, if you purchased it , can you confirm by showing how this will work ? My intention is to use on Daimakaimura Resale game . @lydz , please sir , can you confirm if your board will work with ? i read entire theard but i didn't understand too much on how to be used .
@lydz i took one more crack at this trying with multiple settings for what I assume is B13 could potentially be starting from right and left. Can you look at the pic I posted 3 messages prior and tell me exactly what I need to set the DIP switches to please. Not sure at this point what I can do further to get these to work..
Has anyone else picked one of these up and got a B13 (or B4) going?
I really don't like that lydz doesn't try to help. He was able to advertise his products. When there is trouble, it disappears.
@Darksoft & @brizzo , please can you make something in this matter to get straight answers from @lydz ? If nobody shows how this B-xx C boards works , i'm interested to see if and how it works , like ive seen in @undamned videos about his Infinikey's videos ! Until now from what i read , the buyers of his C board didn't get the results they paid for .
ps : I encountered the same type of treatment from him
@AlxUnderBase It works similarly to infinikey cps1. Here it is integrated with 21 chips plus programmed chip and dip switches. Use the switches to select which game chip you want to use (cps-01, 02 etc) If you have an original Final Fight game, use the cps b-04 chip. On a Lydz motherboard, the panel works as cps b-04 with the appropriate dip setting (dip setting included) That would be it.
I assume the programmed chip may be faulty or the contents inside. Of course, the B-21 chip or other component, I do not know. I got a video that theoretically tested what was mailed to me. It worked on the video. However, I also saw in the video that it was not tested on genuine software. The hardware was an SF2 champion edition b board and it ran in Final Fight so it was a conversion.
https://drive.google.com/file/d/1WXSWXMi52cHn6ZZGsfzzn6tzuyXTcWFG/view?usp=sharing
@BlackLord is it an optocoupler (left to the yellow thing) and a relay (big yellow thing) I see? :S
Could you please post hi-res pics (where components ref. would be legible)?
@Apocalypse
I have tried every possible dip position. I have several original cps1 games. There is one that contains a battery. Only one game started but the picture was very striped. Do you have any idea what can be done? I have two such panels. This is a mistake for both. I think lydz didn't test these enough before he started selling them. It would be nice if he could answer too. Maybe you could say something that would bring everyone closer to a solution.
@ApocalypseI tested a game that is b21 chip and does not contain a battery (original street fighter 2 - champion edition). All dip switches are off, working perfectly. I tried it on an SF2 - World Warrior game that contains a B-17 chip. I set the dip switches to the appropriate position based on the attached document. The result is just a striped image. Same result for the original Final Fight and Magic Sword, Three Wonders (battery included) games. Presumably the code is not loading or the code is incorrect.
Hi all,
How many users bought from this C board? Whoever bought it will tell you that it really works. I bought one, it didn't work. I paid for another shipment, got another c-board, arrived today, I tested it doesn't work. A friend also bought, does not work. Lydz doesn't answer. This is correct?
I bought one and I assume it works fine. I say I assume because I only tested it with my Street Fighter 2 World Warrior (B-17). Worked with no problem.
@-Ace- Can you upload a picture of your motherboard?
Sure- it won't be until later tonight when I get home. I already tore up my SF2 WW (B-17), but I switched the dips on the C board to B-11 for this G-n-G conversion and the game worked fine.
