Kagaden
That's my worst nightmare. I'm so sorryWell I managed to neck the tube while using the rotate mechanism, so the tube is dead and I can’t give you a pic of how it looked when on.
Man that sucks.Well I managed to neck the tube while using the rotate mechanism, so the tube is dead and I can’t give you a pic of how it looked when on.
Oh shit. I've heard this happen beforeWell I managed to neck the tube while using the rotate mechanism, so the tube is dead and I can’t give you a pic of how it looked when on.
This^Do not attempt to rotate the tube unless you have verified that the wiring for the neck board has enough slack. If you're unsure, remove the neck board for safety.
What's the point of a rotate mech if you have to have to disassembly the bezel, lay the cab on it's back, and have a friend help... by that metric every cab has a "rotate mech" because that's the process for rotating in anything else.I recommend laying the cab on its back and disassembling the brackets that hold up the bezel and having a friend to help.
Just like the E3/AWSD. TBH, those Windys look like they will clean up nicely.I was only talking about the windy, it does not have a rotate mech. The monitor is just a tube with the neck board, no frame at all
Good question. I'm just going to have to draw numbers to see who got the short straw and partially compansateSo one of the E2s has a busted illumination panel, whos going to end up with that?
If it's the same guy that was selling them on Neo Geo, he also makes NAC side art. Neither of his products are the correct colors and I've heard the translite is bowed wrong so it falls out. The last time I saw a Taito translite sell it went for $800, but it was NOS in a box. I'd say $600 is what you could get for a decent looking one used, which is why I quoted 6-800.isn't there a guy on neo-arcadia that makes repos? I could have sworn I've seen them for sale within the last year or two.
