90sCyberThriller
that is some good information, thanks. I'm having the same issue where it would turn on and then as soon as you power off it won't cut back on again. I change the hot once and it worked one time then it wouldn't power back on again. I'm assuming it keeps blowing the hot but not sure yet. Was going to order more but they're kind of expensive to test like that.Are you sure it's the flyback? Is there a crack in it? If not, it might be something more mundane, like the HOT having blown, or the B+ voltage being wrong. Having to measure and adjust B+ after a recap isn't uncommon, and Toshiba chassis have a reputation for blowing HOTs after having been recapped. If you get neck glow, that's a sign your flyback might have a chance, since it usually comes off of a secondary winding to get the ~6.3VAC.
There is a pot by the fly back to adjust HV but I don't know what to set it at. My fly back was either replaced or repaired at one point as it had been badly re-soldered at one point in time I posted a pic a couple pages back
