So maybe it is remote board same amount of buttons
Surgery is probably required to figure this out. Hopefully, there aren't too many parts in it. I can check it out again on Wednesday.anyone know of a cap kit or list for konami windy 2 psu
Itchhhhh! That looks overly complexThere are a few pics of the PSU here, not detailed enough to see values but you get the idea of how complex it is.
https://www.gamestone.co.uk/gsrcade/arcade_information_konami_windy_ii.php
that would be overly appreciated. Thank you.Surgery is probably required to figure this out. Hopefully, there aren't too many parts in it. I can check it out again on Wednesday.anyone know of a cap kit or list for konami windy 2 psu
Not yet. Should be here next week.@nem did your container arrive yet?
Yep. He said he only had one working Domy Theater, so it's got to be this one.However, I just looked through the pics that Yaton sent and he has pics of the cab working. It's the same cab, I'm sure.
These cabs are supposed to be converted to 100-110V if I'm correct.So so are you guys removing or bypassing the 220v step-downs?
From what I saw from the Canada order, they had been removed. Can anyone with a windy 2 take a picture of the inside of their cabinet?So so are you guys removing or bypassing the 220v step-downs?
They're supposed to be, yep!These cabs are supposed to be converted to 100-110V if I'm correct.So so are you guys removing or bypassing the 220v step-downs?
Originally, yes. Then Yaton converted them back to 110V. However, they left a wire mess for us to clean up.iirc it was only the nnc that were 220v.
Yep, a Windy 2 with a pb7534 chassis and remote board should work nicely, and is auto switching for 15/24/32k inputs. No dip switches are available / necessary.That combination sounds about right. The Windy has a PB6643-1 chassis, a PB6643-2 remote board and PB6644 neck board.its got a toshiba pb7534-1 with a toshiba pb7534-2 remote board
