Yes, Im in, dont know for what but we doing this Will PM you back.Hmm. Some of you dont seem to see my pm or answer me back
Id like to know if you re or out
@Derick2k
@Derick2k
Sega16 caseYes, Im in, dont know for what but we doing this Will PM you back.
thank man!I'll make a new plate for @asra just to make sure his selector can fits
since i dont own one here. (hole in the middle will be quite larger)
Done, thank you!
I could do SS, but cost/weight would be quite another kind of story.Wow! Looks awesome. Is that Aluminum or SS? If aluminum, I wonder how it would look anodized in some colors? But if anodized , it would not hold up like the powdercoat would. Regardless, case looks amazing. Makes me wish I had an MK pcb.
tabarnak !!!Yuuuup it has a few things to make better and 1 hole on a plate completely off...
But DAMN. it install perfectly.
Cant do much about cables poping outside near jamma plug (for now)
All that is missing is the black color and vinyl.
All cases are also in the painting section.
the version i got have a staked pcb already on it. i see there's some kinf of trick you can do to get rid of it.Very very pretty. Have you considered, rather than doing 2 separate pieces, planning to use https://bit-district.com/arcade/midway/mortal-kombat-2-pcb-consolidation-kit.html to make it a single stack?
I'm likely to buy the case either way, but I DO have the consolidation kit installed and it's quite nice.
Indeed, friendtabarnak !!!
