For my Taito Type X multi i've purchased this model : K91X1025F
ps :
Is good for using with Taito Type X2 too
Does anyone know what the dips on this IO board do? There's 3 banks of 2 dips. Or is there a manual for this one floating around, i tried to find one and couldn't.
@Murray did you ever get the answer to the dip switches?
For anyone that stumbles on this in future and has knowledge on this stuff.
The Fastio boards that only support 4 buttons have a Lattice MachX0 FPGA on there. LCMX01200C-3T100c
Pretty sure this is the JTAG port pinout.
Also here is the official jprogrammer for these things to connect to your jtag port.
https://www.digikey.com.au/en/products/detail/lattice-semiconductor-corporation/HW-USBN-2B/5015900
Way past my level of knowledge but if anyone wanted to try and get the 4 button io's to work with 6 buttons..... Just thought I'd post it for reference.
If someone can dump one of the 6 button units without the jamma edge like K91X1243C, then I'll try to write to one of my 4 button units.
I have a K91X1243A as well, and would be interested in anybody getting 6 buttons working, also was wondering if someone had tried every pin or explored if it just needed a different harness.. I know the New-Net-City cabs have a pin for button 5 Both on the main plug as well as on the "Kick Harness" type plug in the middle...
I’m working on a K91x1243C at the moment and doesn’t seem like I have buttons 5 or 6 working. Anyone share the same experience?
Testing with artax multi, SFV IO test. I will try some others
FAST IO AMP PCB K91X1204B does any one have a diagram how to connect this up to a ttx3 please
Are you asking for pinout for the controls on cab side? Your fast IO should just plug into your X3 with a single Ethernet cable
