I've never played it but I will test it in a few hours when i get home and see what is needed.
Ninja Assault |
Shootout Pool |
The House of the Dead 2 |
World Kicks |
yes, afaik both games uses (almost) same I/OI have the trackball I/O for Virtua Golf and it works great with the net boot Naomi. So it will also work with Outrigger?
technically there is not gun, but analog rotary stickNice, I imagine you still need S-JIHP and a gun setup?
why this here ? Shikigami (1) is Taito G-NET game, Shikigami II is GD-ROM game so its netbootable with no problemsThe Castle of Shikigami
Very cool, I'll have to give the DC controller option a shot soon. I thought it was a possibility being a Capcom game and all.(same principle as Ikari Warriors or Midnight Resistance sticks but full analogue)Nice, I imagine you still need S-JIHP and a gun setup?
this game also supports Dreamcast controller plugged in MAPLE port
I'm using CF. Anyone had success using CF?Crazy Taxi loads fine on my Naomi 2 via net boot.
18 wheeler doesn't load well - has scrambled video. Sound is fine.
Anyone have 18 wheeler working well on Naomi2 net boot?
Ninja Assault uses a special I/O board that connects the VGA output sync signal for use with a traditional style CRT Light gun (lower right). so that game is unplayable unless you have one of those boards. It also uses some video signal converter that separates the sync signal for use with the special I/O board (the small board on top of the NAOMI in the pic below)Ok. Thanks for the clarification.
Ninja Assault and House of the Dead 2 are the big ones - any chance of seeing these gun games available for net boot?
So what exactly is needed for Gun Survivor 2 to work? A rotary stick? A special I/O board is needed, but the beta provided above will allow play without the I/O board and as Mitz states it doesn't quite work yet? It looks like a gun game in most pictures online - just wondering what it takes to get this one working.
Seems to work fine on my setup... NAOMI 2 with Rev C Multi bios.Crazy Taxi loads fine on my Naomi 2 via net boot.
house of the dead 2 works on other revision, not just revA.Ninja Assault uses a special I/O board that connects the VGA output sync signal for use with a traditional style CRT Light gun (lower right). so that game is unplayable unless you have one of those boards. It also uses some video signal converter that separates the sync signal for use with the special I/O board (the small board on top of the NAOMI in the pic below)Ok. Thanks for the clarification.
So what exactly is needed for Gun Survivor 2 to work? A rotary stick? A special I/O board is needed, but the beta provided above will allow play without the I/O board and as Mitz states it doesn't quite work yet? It looks like a gun game in most pictures online - just wondering what it takes to get this one working.![]()
As for House of the Dead 2. As I understand it, it makes use of a different graphics chip that is only present on very early revision NAOMI boards. It also uses a different BIOS that is specific to that hardware revision and does not support Net-Booting.
We did a bunch of testing. On a standard Naomi, loading HOTD2 will boot but it's unplayable because it runs extremely slowly and has massive gfx issues. The interesting thing is that I decased my netDIMM and installed it in my HOTD2 pcb and netbooted the game and it runs EXACTLY the same as it did on the normal Naomi. So it may just be a bios thing after all.house of the dead 2 works on other revision, not just revA.
