Wow, that's the true MVP on this one! Will save a lot of install headaches for sure, top work @Darksoft and team!a connector for the key re-writing so you no longer have to solder wires to the multi.What else?
How do I pre order? It shows out of stock when I add to the basket?PREORDER FOR NEW VERSION OPENED NOW
http://www.saveyourgames.it/index.php?route=product/product&path=89&product_id=54
Correct. No jumper changes required, no PAL change required. No soldering required for key writing wires.So with this change it sounds like it no longer matters what donor B board you have? Since it says "no need to change the original PAL chip".
That's handy if the case, will make things easier for people.
Am I addicted?
Yes but it will be a different cable, it will have connectors on both ends rather than connector and wiresI am new to this kit. If I order the Nov 2020 revision will I still need "4 wires adapter for Multi-CPS2 Key writing Cable" ?
what is not accessible?It's still not accessible from Japan. It's a pity.
Ah okay. Now I see the board part number ends in “-6”. I also see the PAL chips have a D at the end. So should I buy a Preprogrammed PAL G then?That is a rev-6 board (look at the part number) and a D PAL
