Never said the info, I said the filesI'm sure @Apocalypse said it was impossible though. Someone is now saying the info came from him?
Never said it was impossible.Indeed. If a Gunforce can be converted into RTL, it can work with the multi.
I more meant impossible in the sense that it's not a straightforward conversion and the amount of work required to pull it off makes it impossible for the majority of peopleNever said it was impossible.However I did say that wasn't easy due to the reason you mentioned earlier: missing address lines so wires have to be used.Indeed. If a Gunforce can be converted into RTL, it can work with the multi.
A bit messy but doable.
I want to do it due to 2 reasons:Easy to do in 2 steps:
Step 1: Sell Gunforce
Step 2: Buy Gunforce 2
Sorry man, I'm sure it can be done, but GF1 has a much smaller board, so it will be a lot of work, not sure it's worth it. Also a reason GF1 will probably not be a good donor for the upcoming multi M92.
I can do nothing with such a picture... ... ...I guess your best option is to follow the picture above. I don't think those who can do this are going to release the information publicly.
LOLI guess your best option is to follow the picture above.
?LOLI guess your best option is to follow the picture above.
It shows you all the connections on the interconnect pins, you can see where most of the wires are going to on the chips.I just thought your comment to him was funny, peace- like anyone could utilize that picture. . .
At least this one exists and works, i get messages all the time about stuff that does not work and does not exist (yet) demanding info?LOLI guess your best option is to follow the picture above.
Everyone wants the information handed to them, you can always do the work yourself and then document it for others.
So is this saying I should refrain sending that message about turning my Quiz Chikyu Bouei Gun board into Guwange?i get messages all the time about stuff that does not work and does not exist (yet) demanding info
That's a common one, that's the sailor moon hardware again i guess...So is this saying I should refrain sending that message about turning my Quiz Chikyu Bouei Gun board into Guwange?i get messages all the time about stuff that does not work and does not exist (yet) demanding info
I wouldn't mind sharing the info but I don't have a Gunforce board handy to give proper details.I guess your best option is to follow the picture above. I don't think those who can do this are going to release the information publicly.
