Home Arcade System
I don’t see why this wouldn’t work. If you don’t have a scart switch you should be able to use this to switch between different male scart cable inputs.
Yes of coarse you can do that (SCART input, mini din 8 output). That is exactly what it is designed for.
But I thought the intent was to use it with the HAS? In that case the the the mini din 8 would be the input and the SCART port would be the output.
Anyone used one of these cables to adapt the HAS to SCART? https://www.ebay.com/itm/372767506445
That cable is wired backwards from what you need for the HAS. The SCART side is the input and the mini din 8 is the output.
Makes sense, thanks. Anyone got a link/source for the opposite (xrgb input, scart female or male output)?
https://retro-access.com/collections/other/products/8-pin-male-mini-din-to-male-rgb-scart
Thanks so much!
Received my HAS today. Everything looks good upon initial inspection. Shipping was remarkably fast. Thanks so much!
How does the 3P/4P pcb mount on to the HAS? are there screws or something to hold it together?
Nevermind, I looked at the manual.
Got mine today. Everything is perfect. Terminal cover fits perfectly on the mwp606, everything connects and goes together very well. My HD Retrovision component cable provides an absolutely stunning picture on my 32” Sony trinitron. It’s seriously insane. Giving my cps2 and cps3 5.035V tested from the jamma edge using a fluke multimeter. Voltage readout reads 5.04v. Very happy to finally have this.
Thank you RGB!
Thank you RGB!
What is the terminal cover you are refering to? I have same psu and would need a one too.
Thank you RGB!
RGB provided a 3D printed piece to fit over the screw terminals for this batch of the HAS.
Tip: if you’re going to add forks to your power cable wires, don’t make your insulation too thick. In my case, I initially wrapped too much electrical tape and the terminal cover wouldn’t slide over them
So maybe an oversight on my part, is there component video support in any capacity, either through custom cables, a HAT or anything like that? I have a means to connect everything but it's nice to have these options when taking these products to various places.
I think if you get the output adapter that has the PlayStation style av-out, you could use HD retrovision cables with the PS adapter.
It's called a SCART to Component adapter and they've existed for about 20 years now.
If you have need for component, I highly recommend you invest in one (not Playstation hats and HD Retrovision cables).
IMO HAS is perfect just the way it is (8pin mini din RGBs) the only reason why I own a HD15 hat is for the Taito F3 workaround with OSSC...
And that's to solve an issue with the OSSC, again HAS IS perfect just the way its is... Its the OSSC that's flawed.
