kryssss
That cable is wired backwards from what you need for the HAS. The SCART side is the input and the mini din 8 is the output.Anyone used one of these cables to adapt the HAS to SCART? https://www.ebay.com/itm/372767506445
Yes of coarse you can do that (SCART input, mini din 8 output). That is exactly what it is designed for.I don’t see why this wouldn’t work. If you don’t have a scart switch you should be able to use this to switch between different male scart cable inputs.
Makes sense, thanks. Anyone got a link/source for the opposite (xrgb input, scart female or male output)?That cable is wired backwards from what you need for the HAS. The SCART side is the input and the mini din 8 is the output.Anyone used one of these cables to adapt the HAS to SCART? https://www.ebay.com/itm/372767506445
https://retro-access.com/collections/other/products/8-pin-male-mini-din-to-male-rgb-scartMakes sense, thanks. Anyone got a link/source for the opposite (xrgb input, scart female or male output)?That cable is wired backwards from what you need for the HAS. The SCART side is the input and the mini din 8 is the output.Anyone used one of these cables to adapt the HAS to SCART? https://www.ebay.com/itm/372767506445
Thanks so much!https://retro-access.com/collections/other/products/8-pin-male-mini-din-to-male-rgb-scartMakes sense, thanks. Anyone got a link/source for the opposite (xrgb input, scart female or male output)?That cable is wired backwards from what you need for the HAS. The SCART side is the input and the mini din 8 is the output.Anyone used one of these cables to adapt the HAS to SCART? https://www.ebay.com/itm/372767506445
Mike sells the option boards with new standoffs/screws to attach them to the HAS, you'll use the same plexi.How does the 3P/4P pcb mount on to the HAS? are there screws or something to hold it together?
What is the terminal cover you are refering to? I have same psu and would need a one too.Got mine today. Everything is perfect. Terminal cover fits perfectly on the mwp606, everything connects and goes together very well. My HD Retrovision component cable provides an absolutely stunning picture on my 32” Sony trinitron. It’s seriously insane. Giving my cps2 and cps3 5.035V tested from the jamma edge using a fluke multimeter. Voltage readout reads 5.04v. Very happy to finally have this.
Thank you RGB!
RGB provided a 3D printed piece to fit over the screw terminals for this batch of the HAS.What is the terminal cover you are refering to? I have same psu and would need a one too.Got mine today. Everything is perfect. Terminal cover fits perfectly on the mwp606, everything connects and goes together very well. My HD Retrovision component cable provides an absolutely stunning picture on my 32” Sony trinitron. It’s seriously insane. Giving my cps2 and cps3 5.035V tested from the jamma edge using a fluke multimeter. Voltage readout reads 5.04v. Very happy to finally have this.
Thank you RGB!
Hopefully I can get one too even when having HAS already.I think if you get the output adapter that has the PlayStation style av-out, you could use HD retrovision cables with the PS adapter.So maybe an oversight on my part, is there component video support in any capacity, either through custom cables, a HAT or anything like that? I have a means to connect everything but it's nice to have these options when taking these products to various places.
It's called a SCART to Component adapter and they've existed for about 20 years now.is there component video support in any capacity, either through custom cables, a HAT or anything like that?
