msamiullah
This is what I thought but even after changing the switch to TTL I still get 1v on SYNC line on MD8.I don't recommend using CN2 if you aren't 100% sure (check your monitor specs). Also, there's a 75R/TTL switch that affects CN5 and 8pin mini DIN outputs.Found out the issue. I measured the V on CSync was around 1v however changing the Csync line (from to Dnto CN2 did the trick. Does that mean my device was expecting TTL level sync ?
