The voltage level output for the sync signal.What is the difference between both mode ?
I get very low sound output on Donpachi with the HAS. Cab not near me for testing, so curious if it is the same. I should go rescue my cab from storage.Hey. I'm double testing a couple bootleg boards on the HAS that werent working in my NAC.
For some reason. I cannot get sound to work on the HAS.
I have it connected through Mini Din to SCART and my other scart consoles sounds are working great the Banbridge auto switch.
I even hooked up an headphone to RCA adapter I cannot get sound to come through.
I feel like I'm missing a basic step here...
Edit: I used a PCB that had working sound on my NAC but didnt work on HAS. But when I plugged in the M-72 Multi. The sound was working.
I wonder what makes certain PCB's have sound on cabs but not HAS..
I don't have Donpachi, but I have Sailor Moon, Gaia Crusaders, Fever SOS, ESPrade, Uo Poko, and Power Instinct and I think they are on the same PCB, no sound issues at all with my HAS v4.So as a follow up, since Donpachi outputs curiously low sound on the HAS and I have tested with 2 different Donpachi PCBs, I am leaning towards this being the impact of the audio attenuation circuit in the HAS itself.
@RGB - if I were to bypass the HAS audio attenuation circuit, could I simply remove what I assume is just 2 resistors and bridge the pads where each resistor used to be?
Can someone else test a Cave 68000 based game and report back?
I already tried that before,but like I mentioned in the post the start & buttons are not being recognized (except coin and joystick) so I can’t enter the button reconfiguration MODE of the HAS.(you have to hold start and 2 buttons to enter that mode)@merrygoomba Based on what it says on the HAS manual your button layout is not set so you will need to reconfigured your button layout. Here is the link to the HAS Manual , #23 of the Q&A section. Also in the manual are instructions on how to configure your button layout.
That is something you can try and see if it fixes your issue.
@merrygoomba You have probably done this but but i gotta ask. Have your tried a different controller/arcade stick, have you checked the buttons and connections to see if its a loose connection?I already tried that before,but like I mentioned in the post the start & buttons are not being recognized (except coin and joystick) so I can’t enter the button reconfiguration MODE of the HAS.(you have to hold start and 2 buttons to enter that mode)
The creator is temporarily not taking orders. See here:Hi guys
is there any news about the HAS supergun?
I am looking forward to buying one![]()
Can't help with the cables but I use the hat with an OSSC specifically for Taito F3 which won't sync with the OSSC via AV1.![]()
Can anyone help a ninja out?
When I purchased the HAS I just opted to buy every cable he made optional because in the future I wasn't sure what boards I was gonna land on. Well I landed on some and need to know which cable is which.
According to the receipt I should have a
I know the green is a CPS1 and I have the CPS2 hooked up.
- STV
- Konami
- 3P4P
- I think one is a midway?
Also what use case is the VGA hat for someone who uses a XRGB Framemeister but is thinking of going OSSC?
Thanks!
No.I think all of the cables (except the green cps1 kick harness) are 3/4 player adapters, are you playing 3/4 player games right now?
You were saving it for me! I was wanting one.Also what use case is the VGA hat for someone who uses a XRGB Framemeister but is thinking of going OSSC?
Thanks!
