Home Arcade System
I would like to order one... hopefully i will be able to see when preorder is up...
Hey guys, i have a CPS1 question. I recently got my first CPS1 board (Street Fighter2) and when trying to use my HAS CPS1 kick harness i was not able to connect it to the C Board. So i made some alterations to the kick harness to get it to connect to the C Board. Now its connected but there are still no kicks. My CPS2 games work fine with kicks so its not my joystick. Are there different pinouts for CPS1 kick harnesses? Just a bit confused. Any help would be hugely appreciated. Thanks! :)
Can you post some pictures showing the modifications you made and where you are plugging it in?
Sure! Pictures are attached. It would not fit so the only modifications i made were to the connection on the kick harness on the board end. To be clear, i only shaved some of the plastic off of the connector.
The pin out for the CPS1 kick harness is different from CPS2 and CPS3. See pinouts here.
Yep. Just confused. Don’t know why my HAS CPS1 kick harness does not fit this C Board. I guess there were different connectors used per CPS1 C Boards?
Okay. Thanks for the info guys! I think i got it figured out. I just had to modify my cps1 kick harness and swap the wires around got all my kicks working now! Super stoked. I think it is a none stock connector on my C Board. All good. Can swap it some other time. Again, thanks guys!
Mine just updated and fedex said "clearance issues have been resolved for your package" and the "shipment has been released for delivery." So I wonder if it has been gone through/opened by customs. I should find out tomorrow when it's delivered.
They did that to mine too. Seems to have survived as far as I can tell. Hopefully I have time tomorrow to assemble and fire it up. Definitely a good mail day!
Haha US Customs probably saw quite a bit of these thinking WTF!?! :D I'm sure it didn't help it was numerical display with wires and a bare PCB. Looking forward to your result. Still waiting to buy the PSU.
