Home Arcade System
Received mine today and can't wait to check it out. Thanks so much for the fine work.
  • Like
Reactions: RGB
My HD-15 HAS adapters arrived today...
Hope to test them out this weekend using the Taito F3 and my OSSC.
Install shots (and my one cord HD15+3.5mm solution)...
For the OSSC to lock the the F3 via HD15 adapter, the HAS must be set to output Buffered TTL Sync.
Open/remove the jumper at location #17 (TTL) and move the jumper at location #18 to center (buffered).
The OSSC must have both its Pre/Post Coast set to 4, and be in mode AV3: RGBS (the first/default mode is AV3: RGBHV).
haveing a little bit of a problem. I am getting interference on rgb out. I did buy the cable rgb mentioned to get from the nesrgb guy. Im not sure if its the cable causing this because it doesnt looked like its shielded or could it be my psu. Its kind of old from an arcade cabinet.
Ps i did fix my power button issue bought a cord with inline switch
The supergun I use it with already has an ATX connector for power, so just plug and play. I also have a Mak Strike which accommodates a 4 pin IDE plug which the Pico accomodates. To power the Pico I use an old external hard drive PSU which is 12V 2A. This provides around 5 Amp from the Pico PSU 5V line which is adequate for most boards.
You could easily fabricate or buy a cable with 8 pin ATX power connector on one end (to connect to the Pico) and whatever the HAS needs on the other.
Hello there. I have a Mak Stike supergun and was looking into getting a HAS.
I have this PSU for the mak strike.
http://arcadeforge.net/Supergun-MAK-Strike/5V-and-12V-PSU-for-Arcade-and-PiJamma::107.html
Will that PSU work with the HAS? Just doing some lite arcade gaming with pandora box and some jamma boards. Not a fan of the bigger psu's The size I linked to is what I would like.
Also would like to hook up the HAS to my OSSC. What adapter would I need to connect to the ossc? Can someone link me to a few ideas?
Cheers
