AlxUnderBase
Enlightened
Also OSSC in comparison with Xrgb Mini is a lagless device and this is most important IMOOSSC isn't a line doubler per say, it's a scan converter which is also a line doubler somewhat. A line doubler takes a 240p image and effectively just duplicates them to make a 480p image. This doesn't require any intricate math or anything crazy so it requires almost no buffer and has almost no latency impact. A scan converter is a line doubler but it also is capable of attempting to convert to 720p as that is a direct integer conversion from 480p which mostly doesn't require a buffer either. The timing however isn't normalized so a lot of displays don't like the 720p signal as it is not 60hz.hey @jassin000 a noob question for you, I have been doing some reserach on OSSC and Framemeister. A lot of people refer to "Framemeister" as an upscalar vs line doubler for OSSC. Does this mean that with "Framemeister" the image becomes softer as it is displayed on HDTV ?
Framemeister or XRGB-Mini is an upscaler where it takes a 240p, 480i or 480p input and can use integrated ics to do a smoother conversion to hd resolutions as 1080p doesn't have a common denominator like 480/720p. It's also much, much easier to use in comparison to OSSC however there are a ton of profiles made now for OSSC which isn't as big of an issue now.
