Yep. Just confused. Don’t know why my HAS CPS1 kick harness does not fit this C Board. I guess there were different connectors used per CPS1 C Boards?The pin out for the CPS1 kick harness is different from CPS2 and CPS3. See pinouts here.
That connector on your C-board doesn’t look stock to me, they are generally white. Any idea if a previous owner replaced it with a different connector?Yep. Just confused. Don’t know why my HAS CPS1 kick harness does not fit this C Board. I guess there were different connectors used per CPS1 C Boards?
Heh i suppose that’s possible...That connector on your C-board doesn’t look stock to me, they are generally white. Any idea if a previous owner replaced it with a different connector?
They did that to mine too. Seems to have survived as far as I can tell. Hopefully I have time tomorrow to assemble and fire it up. Definitely a good mail day!Excited to finally get my HAS, a little weary that US Customs and Border Patrol ravaged into the package.
Mine just updated and fedex said "clearance issues have been resolved for your package" and the "shipment has been released for delivery." So I wonder if it has been gone through/opened by customs. I should find out tomorrow when it's delivered.
I’m happy to say mine arrived unmolested.Haha US Customs probably saw quite a bit of these thinking WTF!?! I'm sure it didn't help it was numerical display with wires and a bare PCB. Looking forward to your result. Still waiting to buy the PSU.
Good to hear! My box was opened, just wasnt sure if they took out the PCB from the plastic bag.I’m happy to say mine arrived unmolested.
I would guess they wouldn't need to open the bag to see that its just a pcb. Where were you looking at buying your power supply from?Good to hear! My box was opened, just wasnt sure if they took out the PCB from the plastic bag.
I was looking at Axunworks PSU. Planning to get a custom cable to fit HAS. There on Arcade Projects also.I would guess they wouldn't need to open the bag to see that its just a pcb. Where were you looking at buying your power supply from?
the custom cable your referring to would that take advantage of the white connector on that psu?I was looking at Axunworks PSU. Planning to get a custom cable to fit HAS. There on Arcade Projects also.
https://www.axunworks.com/product-p669351.html
Correct. According to the Axun team. Just need to provide specs, which seems straight forward.the custom cable your referring to would that take advantage of the white connector on that psu?
That's a good question for @axunworksWhat is the AWG on that cable ?
Axun said:
Outer diameter: 9.9mm , inner core diameter: about 2.3mm (17AWG)
Uses: sensors, power lines, signal lines, PLCs, servo signals, drag chains, tank chains, manipulators, robots, etc.
Features: soft and fold-resistant, anti-ultraviolet, working range of minus 40-105 degrees, oil and acid resistance
