fallinlight
The cable would have to make use of pin #9 of the HD-15, and it looks like the Retro Upgrades cable doesn't use it. The RT cable definitely doesn't use it, as stated earlier.
The mod would be simple; you would need to provide the +5V to the Scart head as in the diagram above. You could install a USB type A socket/female cable in the Scart and tap power from the HAS using a USB-C to USB-A cable.
Ah, thanks very much, OK. So, I need a 180 ohm fuse for that mod.
What you said about a USB cable reminded me, I did come across this one from Arcade Express yesterday, would it work?
https://www.arcadexpress.com/en/vid...RH7IGxUW6y1qwiatQjcfMPBFZH1y30kpVzZxh4aBhaR-4
Thanks
