Irken (MiSTer) JAMMA Expander
To be honest, I think getting a JAMMA 2-in-1 switcher would accomplish what you would want more easily than trying to shoehorn a Pi into the JAMMA Expander, but it's your money and free time lol...
Hi, I've been trying to display vertical games rotated on my horizontal tri-sync using the jamma expander but it does not look like the "vga_scaler" works with direct video.
I was able to rotate the output using the VGA port on an analogue IO board though using that "vga_scaler" option.
Is there a way to do that with the expander?
Maybe setting the output with "video_mode=6" (640x480) and not using "direct_video"? Would the expander accept that HDMI signal and output on 31kHz ?
Best solution is to rotate the actual monitor 8)
Well, I don't disagree that's the whole point of getting as accurate emulation as possible but there are cases where rotating the monitor is not an option :P
I tried with just setting the "video_mode=6" and the expander OLED display states 31.xkHz output and the SyncGuard states OK (set to trisync) but I get no image on the monitor. So apparently the expander recognizes the HDMI signal. Could there be something with the sync signal ?
Probably not, I presume the sync is OK but that the actual output is not ok (from mister) - or try another core with those settings (the nullobject cave cores leave a little to be desired..)
New firmware with new USB stack, which in turn have allowed me to remove a few artificial delays in the code. In the process I've also updated the entire build environment, updated vendor libraries etc so bugs may have snuck in. I've tested it a bit but would be fantastic if you guys could give it a go and report back before I announce.
https://irkenlabs.com/firmware/jexpand-2023-08-31.zip
New update for all Jamma Expander revisions : https://irkenlabs.com/jamma-expander/firmware-update/
Super easy update procedure :happy:
I forgot that I took a pic of this during EVO. I saw a JAMMA Expander V1 in the arcade area that used the 3D printed case I designed for it. I typically don't really get much feedback from people when I release designs, so I'm glad that I can see someone out in the wild who finds some use out of them.
Anyone have P1/P2 issues with the expander in gamepad mode? If so, I may have a fix that doesn't include messing with ini files..
Hi @invzim, do you have any solution for this particular problem ?
I'd like to assign permanently P1 and P2 in gamepad mode but it's not consistent with mister.ini
I thought I solved the issue with this setting :
; Permanently assign specific controller to specific player.
; Normally you don't need to use this option, but if you use arcade cabinet with integrated controllers then
; you may want to use it for specific player regardless which controller is used first.
; To assign it, you need to provide unique part of this controller ID.
; In USB debug log you may see list of input devices right after core has been loaded.
; For example:
; opened 0( 0): /dev/input/event8 (1915:0040) 0 "7c:10:c9:15:22:33/df:47:3a:12:44:55" "Flydigi APEX2"
; opened 7( 7): /dev/input/event3 (1997:2535) 0 "usb-ffb40000.usb-1.6/input0" " mini keyboard"
; opened 9( 9): /dev/input/event0 (046d:4024) 0 "usb-ffb40000.usb-1.2/input2:1/4024-19-a2-39-0a" "Logitech K400"
; following part is unique identifier in system ^^^^^^^^^^^^^^^^^^^^^^^^^^^
; So you need to provide part of this string identifying exactly this device. Don't include inputX part as it may change after reboot.
; Wireless devices usually have format MAC/MAC, wired devices use usb-... format.
; UPDATE: you may define up to 8 devices to the same player. Use player_1_controller in several lines to assign multiple devices to player 1.
; Example of such unique part of strings:
player_1_controller=2087388B344E/1
player_2_controller=2087388B344E/2
;player_3_controller=
But it seems it doesn't work anymore.
And for the life of me, I can't begin to remember how I ended with these values :
I know they used to work and I managed to get them while messing with putty, but hell now I'm at loss.
Any help here please ?
New limited batch in the works! Who knows which FPGA gaming solutions will actually ship, or when, or how they will turn out - with MiSTer you know what you're getting. I too was tricked into thinking something was pretty imminent about a year ago, so I didn't make more expanders - but as I've gotten a few requests from operators to make more board, I'll give it a go.
I should be getting the boards just before I leave for a 6 week trip mid June. If you miss the first 'window' sales will reopen in August, pending availability.
I may do a hidden purchase link for those on the notify list, and even if I don't, the order window will be very tight - so if you're thinking about getting one I recommend signing up for a notification at https://irkenlabs.com/product/jamma-expander/
These are of course the rev 2 with USB hub and fancy cables (that also does a seppuku if connect the JAMMA connector upside down - so please use a JAMMA key...)
A thought... I have a video capture card with HDMI in and out.
Do you think it would work to connect it in between the output of the mister to the input of the jamma expander and capture video like a man in the middle? Product in question.
No, because the MiSTer -> JAMMA Expander uses MiSTer's direct video mode, which is not HDMI compatible. Your capture device won't know what to do with the direct video signal.
like @NFGx pointed out, probably not. You will likely need some fancy hardware/software combo to be able to make sense of the direct_video stream (I think the latest retrotink scaler can do this).
You can still use regular jamma capture devices as normal on that side of the setup I would assume
yes I have betsubetsu and ossc which was originally intended for pcb's. but putting a capture card in the middle (if it was possible) would've eliminated the extra equipment needed if I wanted to do something quick with mister.
Just got word that production is delayed, so won't be able to ship out before summer :( Units will be available early August, preference will likely be given to those that have signed up for notification here, https://irkenlabs.com/product/jamma-expander/
