LoneWolf24
Same here. Nice work & in for 1 when it materializes. Looking forward!
Those pcbs fail from the TL084 preamplifier and the AD1851N. You can use an audio signal tracker or an oscilloscope to see if the signal enters the TL084 preamplifier and leaves it to the tda amplifier.¡Hola!
Perdón por salirme un poco del tema.
Pregunta sobre la ROM de prueba : ¿se puede usar para depurar problemas de sonido con la placa? ¿Esta ROM de prueba es diferente del menú de diagnóstico predeterminado?
Después de un poco de depuración, sospecho que el problema con mi placa podría estar en algo entre la CPU y el chip de sonido (ADSP-2105).
yeah, in fact it's so easy, that a member of this forum has been selling the dual games on KLOV and Facebook for $1K+.....You don't need this board to dual boot KI1/KI2 - if you go back to the beginning of the thread, its fairly easy to get it going with off the shelf parts.
https://www.arcade-projects.com/threads/killer-instinct-dual-board.5929/page-6
Neku should make it simpler and easier and prettier, but yeah...![]()
Exactly, sold 5-6 of them (reg board with SSD upgrade) for around 1200-1500 USD a piece. Kept a board for myself to install the dual mod at some point for my own cab but downsizing the collection considerably. Helped me fund the new pinball addiction lolConsidering some people are asking 1k+ for "normal" ones (run a search on the marketplace), that doesn't sound that bad?
Thanks a bunch! I came pretty late to the party and I actually had not read the entire thread.. I thought Neku's solution was the only one so far. I ordered 27c801 roms and a dual CF board , but was shipped a board with only 1 CF connector populated. Haven't heard from the seller yet.. I then decided to read the entire thread its only then I realized that DogP solved the IDE issue a few years agoYou don't need this board to dual boot KI1/KI2 - if you go back to the beginning of the thread, its fairly easy to get it going with off the shelf parts.
I have made available patched roms to be able to run either games on either boards thus you can do the mod on whatever board you have available.I've read through this but it's still unclear to me if the mod is possible with a dedicated KI2 pcb? or must you have a KI or KI2 conversion board from a KI?
I was hoping it could be done with a dedicated KI2 board as I like KI2 better but on occasion would like to play KI once in a while.
Believe my KI2 is a dedicated board.
Thanks
Go back a few pages to post #475 where Neku gives some more specific details. Follow the KI1 & KI2 any-board ROMs link in his signature for the files.I've read through this but it's still unclear to me if the mod is possible with a dedicated KI2 pcb? or must you have a KI or KI2 conversion board from a KI?
Thanks
there's like 800 pages on this thread now, do you know where I can obtain this test rom?Hello, I only recently found out about this project - great work!
I have two boards I'm trying to repair. When I try the Neku test ROM, it constantly resets after drawing the 'KI' and seemingly starting to draw the text. I know the answer might be bad RAM, or bad CPU pins but I wonder if there is any hint from the reset being at this specific part of the test program boot sequence? (Like - maybe it hits the first vblank here, does an IRQ and then the stack RAM is bad so it crashes?).
Thanks!
