Hi Neku, I recorded the results here. May be of interest:
View: https://www.youtube.com/watch?v=lHWqDbcQt2k
That for the multi, it's not released yet.Is there a pcb we have to make for the rom chips? I thought I read mention of that
Yes, i am working on a multi ROM containing both KI1 and KI2 and it's working with a single drive for both KI1 and KI2.Question: I know that it was discussed that it would be theoretically be possible to run bot KI1 and KI2 on the same HDD by reworking the starting sector that each game looks to pull the game files off the drive. I saw the release notes on github mention that option is in a menu. Does this mean that a one drive/SD/CF card solution is in the works?
Neku, are there any tips or specific details on how the combo KI+KI2 needs to be created in order to work correctly from one single Flash/HD card like in your video?Yes, i am working on a multi ROM containing both KI1 and KI2 and it's working with a single drive for both KI1 and KI2.
You can see it working in this video :View: https://www.youtube.com/watch?v=DUH0ATRGXPo
There's some additional hardware in the making to handle the sound rom bank switching.
I will provide the combined disk image.Neku, are there any tips or specific details on how the combo KI+KI2 needs to be created in order to work correctly from one single Flash/HD card like in your video?
This will indeed be awesome!I will provide the combined disk image.
It's not just the two files merged together in a single disk image.
Hi!I will provide the combined disk image.
Arcadecup used to sell DOMs for KIs. I'm most curious how you write both games to the same drive, cause it's not like the roms where you can just bank switch.Question on this, what is the benefit of going with a CF card over, say a DOM (Disk on Memory) drive, which is basically just an IDE SSD?
I was thinking about getting something like this to replace my current CF card. it would sit flat and should be large enough that it would fit both games in it. this way I would avoid bulky attachments
the bios is looks for a specific sector to get boot info, IIRC all that was needed was to edit the sector that KI2 was looking for the data and BAM.Arcadecup used to sell DOMs for KIs. I'm most curious how you write both games to the same drive, cause it's not like the roms where you can just bank switch.
Which file exactly ?Has anyone gotten the neku ki1 u.98 rom to boot…I just get a black screen. The test rom works correctly!….
Just wanted to try while waiting for the dual boot rom and combined hdd image release.
I tried 19489-ki-l15d.u98 on a ki 1 board and just got black screen.Which file exactly ?
On a KI1 or KI2 board ?
I have recently burnt a KI1 rom for a KI2 board from the github and it was working.
I did not test the KI1 rom file for a KI1 board (only tested it in MAME), if that's the one you are trying to burn i will test it against one of my boards.
Tested it with the same file against two of my KI1 boards and it works correctly.I tried 19489-ki-l15d.u98 on a ki 1 board and just got black screen.
Amazing work by the way…thank you! really looking forward to the multi rom and hdd image…
