Mark of the Wolves Reverse Engineering thread
I'm willing to bet that a 1:1 copy of this neo-sma will not be made because the cassettes are low budget.
I'm betting on a software solution.
I've thought about this before and it will be fun to see the people dump that comes out.
If AES+ Garou comes really full decrypted, that is going to be fucking incredible if it is dumped.
I'm using Claude to fix the Kof 2000 s-rom problem but I need someone with a Flashcard to test it too.
Tested on Mame and working fine.
Is there anybody here who can help? If you PM me directly, I can send you the file already patched.
So its time ?
Its time do some work on Mark of the Wolves and NEO-SMA with current IA ?
Well, I actually already have a patch for Garou. Again, tested and working in Mame and based on the work of darknezz19 and programmed by Claude, I only did the testing. But I would like to confirm it's working in real hardware before programming it into a 161.
I don't know if I can post the roms patched here, but if it's allowed I can share the links of Garou and Kof2000.
Please tell me more, you work around neo sma or it's a path on prototype ?
Great idea to leverage Claude for this @Misos .
I don’t have a flash cart but I’m sure someone can test
I have a NeoSD Pro AES flashcart and can perform tests in real hardware. Just let me know if you still need any tests to be carried out.
