the Goat
Vermont, USA
It has been said that the LPF labels are backwards when using a switch. This means that the LPF in ON when the switch indicates OFF and viceversa. Does this apply to the SYNC switch as well? Are we sending a TTL SYNC when the switch indicates 75 ohm SYNC? Please someone confirm. I don't want to damage my SCART equipment. Thanks.
Does the minigun have a switch for TTL Sync? The ones I had didn't. But they were not the latest version.
Raph_friend
Amazonia, Japan
No, the sync just bypass THS and that's it.
You can still mod your Minigun, mine for example has a sync stripper.
Unfortunately Frank didn't release the final version of Minigun.
the Goat
Vermont, USA
Eh? I'm certain sync is attenuated and buffered through the THS.
evilsim
Sydney
the 9 pin mini din version has a switch (if you install a switch, or you can use a basic jumper) for TTL sync or 75 ohm sync. you need to use a MD2/Genesis2 cable for these intead of an 8 pin mini din cable.
I have (only a few of) these boards avail if you wish me to send you one for a small fee. just PM me.
thanks
mbandala
Lancaster, UK
thanks
Yes, mine is a Genesis 9 pin version and it has a switch. So it means that the 75 Ohm/TTL labels are correct if you use jumpers but an installed switch would be pointing to the wrong SYCN option? Just like the LPF switch does?
nem
Finland
If the same switch is used, yes.
You can double check with a multimeter.
Raph_friend
Amazonia, Japan
Which version are you talking about? Could you please show a picture?
hatmoose
Auckland
The LPF switch in the BOM is a weird one, its a reverse throw slider, so when you slide it left it bridges right - never seen anything like it.
If you just use a plain jumper then the silkscreen is correct for the LPF
Regarding sync
- The Minigun Supergun 2.5 9-pin version can switch between 75 and TTL sync
- Minigun Supergun 2.5 8 8-pin version only outputs 75 sync.
The sync switch on the 2.5 9-pin is a jumper in the BOM, and if you use a jumper then the silkscreen is correct.
I'll dig some out in the next few days and post pictures
mbandala
Lancaster, UK
The Advance 2.5 Sega Genesis 9 DIN version has two slide switches, the kind that are always inverted due to their mechanical construction. See the photos below, my minigun there is set up for LPF = ON and SYNC = TTL which is really counterintuitive. It is definitely better to have jumpers there to avoid confusion.
Raph_friend
Amazonia, Japan
Who mod this?
Kujako
USA, California
Interesting... switch looks right, mine has a jumper but no reason the switch would work inversely.
mbandala
Lancaster, UK
All slide switches are like that. The one on your minigun surely as well. You can confirm that with a multimeter.
Kujako
USA, California
Realizing my picture got shrunk down to small to make out, but I have a jumper on the the sync and a slide on the LPF. Both seem to be correct on mine.
mbandala
Lancaster, UK
That is what I thought about the LPF slide switch on mine. I was puzzled by the fact my games looked better when the slide was on OFF. I later confirmed that meant the opposite, my LPF was on ON according to my multimeter. It does not matter here, having the LPF on or off is harmless, you just slide it to whatever look best. One must be careful with the SYNC output if you have a switch though. I am thinking on installing jumpers on mine to avoid mistakes.
Who mod this?
No one. This is the latest original design from this thread's first page (it's the 9 pin DIN version).
Raph_friend
Amazonia, Japan
Got it. DIN8 is my version. I've never seen the DIN9. Thanks.
Kujako
USA, California
Confirmed with a multi-meter. My switch slides in the correct direction, shown here in the off position. (shrug) I'll grant that my slider switch is "fancier" than most. But I also don't really notice a difference in the video quality in either position. So I may be missing something or it's just my setup (OSSC to original Vewlix "C" LCD). But for sure, the two pins on the side of the switch that the slider is on are the two that are shorted.
Elfoam
Australia
The filter is a waste of time really, the average human eye can't see the difference between settings. If you want to save money just install a jumper on that and leave it off. Inflation is really starting to hit and building these is getting more expensive by the day
mbandala
Lancaster, UK
I envy you... I wish I had two of those unreversed slide switches. I don't suppose you know or can see a part number?
I see your point. At least on my set up I can see a real difference, ON look better.
the Goat
Vermont, USA
I belive this is the correct part:
https://www.digikey.com/en/products/detail/nidec-copal-electronics/CL-SA-12C-02/4010211
Viewing directly on an RGB CRT I can hardly see a difference. But I'm told it helps with some video processors that digitize the analog signal. OSSC for one.
