Would you be interested in buying an N64 to Aleck 64 Cartridge Adapter?
  • Total voters
    28
S
SCUltra
Everdrive 64 X5 probably will work but I bought x7 because it's out of stock at krikzz.com. I've never used Everdrive 64 before, I have to learn more about it. I'm not sure why it has problem with Aleck 64 panel if I connect 2 players.
Most of the codes I have seen are geared towards cheating, but having codes to remove anti-aliasing just makes me curious what could be possible via everdrive/gameshark. https://www.retrorgb.com/n64blur.html
Cyothevile
Usa
Interesting. So I guess for the console guys this is the way to get native RGB for N64 games albeit quality could be questionable.
skusuma
Orange County, CA
@twistedsymphony Thank you for sharing your file. I still need to find the screws (I'm temporarily using tape for now).
skusuma
Orange County, CA
@twistedsymphony You mentioned the screw size is 6x 6mm M2 coarse thread cutting screws with 4mm diameter heads. What does 6x6mm M2 coarse thread cutting screws mean? I'm not familiar with screws convention. Is it 2mm screw diameter (M2) with 0.6mm thread pitch and 6mm length (6x 6mm) and 4mm screw diameter head?
twistedsymphony
NH, USA
no
6x is the quantity. you will need six screws in total
the screws are 6mm in length
the screws should have a 4mm diameter head
and the thread pitch is M2 COARSE
Coarse means it has a very deep and very wide thread to cut into the plastic, it is NOT a machine screw with a fine precision pitch.
like these: https://www.amazon.com/gp/product/B01M0DCPQ5
