NAC Splitfire: JAMMA streaming solution
I am very interested in getting one. Can you also put me on the list?
Likely just normal negative composite sync on the H pin? I don't see why it would be split to horizontal and vertical.
75ohm, correct. It's in the bullet points in the OP.
Yeah, I noticed the reference to 75ohm in the OP, just wanted to make sure I was understanding correctly. Just passing through composite sync to the DE-15 is what I'd expect, but I think my brain might've been like "but it's a DE-15, what if it's H/V", which is how I ended up down that line of questioning. I suspect you're right though, and it's probably just passing it through as-is.
Appreciate the response!
