No worries bud. If it helps for future searching I did the following:
1 ) First I went to > https://www.jst.co.uk/products.php
2) They're a wire to board type connector so I selected the 'PCB Connectors / Tabs' option:
https://www.jst.co.uk/products.php?cat=1&nm=PCB+Connectors+from+JST
3) I then selected the 'Wire to Board Connectors (Crimp Type)' option:
https://www.jst.co.uk/products.php?cat=30&nm=JST+Wire-to-Board+Connectors+(Crimp+Style)
4) From the 'Advanced Search' option I changed the '03 - Pitch/Style:' filter to 'more' and then '2.50mm'
This then lists all of the 2.5mm pitch connectors. I then just looked for an image which matched yours which was the last result on page 2.
I find searching by pitch the easiest way to narrow down and ID a connector. If you have the connector to hand you can normally pretty easily measure the pitch, espoecially if you measure the width of say 10 pins and then dividing by n-1 (9 in this case). You'll get a more accurate result than trying to measure the pitch between two pins. Especially when trying to ID if something is 2.50mm or 2.54mm for example.
