Sp33dFr34k
Any clue as to what the Suzo Happ guns use for a connector? It's the big 6 pin sucker on the right here.
That's the one!
then nem is right, it's this one: https://www.digikey.ca/en/products/detail/molex/0050842060/134558
Found them, after some intense reverse image search, they're ELR-12V and ELP-12RLooking for some assistance please with these ones from a Korean DDR cabinet, it didn't come with the cable that connects the cabinet to the dance pads, so I need to build one myself, since also from both sides the connectors are the same gender, but couldn't find what they are.
Japanese DDR uses JST YLP-12V, YLR-12V, VLP-06V, VLR-06V, but this cabinet clearly uses something different. It can't be seen in the photo but they all have male pins. Thanks!
And found a better picture https://www.jessewolcott.com/korean-ddr-pad-connector/
Unfortunately they're very hard to get unless purchased by a large amount.
It's very similar to the one I have in my Neo Candy.
Same connectors, similar pinouts.
Haha@Mrhide - You might give a shout to this guy.
http://zzzaccaria.com/arcade/arcade.htm
His email link is on the page i posted.
He has a page documenting his work on a Quasar here.
http://zzzaccaria.com/zzz/QuasarRestorationMC.htm
If he doesn't reply, put a metric and standard ruler on the pins to find the appropriate pitch....probably metric as they're european....but not definite.
Once you have the pitch, you should be able to find SOMETHING from molex that will make due.....
not a lot of documentation on Zaccaria stuff, to be fair.
TJC1-5YWhat is the name of CGA connector please ?
