chinitosoccer
plays blind, I can hear high current noise (a chirp first then an stable low pitched hum ) after powering it on but no neck glow, meassured B+ at TP2 at 76volts DC.
The neckboard has had its socket replaced at some point with another one taken from a MS8-29, but after further inspection on the solder side of the PCB I have found that some pins are not making contact because there are no solder pads:
4 and 12 pads are tottally gone, while the others look bad, checked ok for continuity, I tried to follow where these pins with missing solder pads go but found nothing??...where do these go?
