you were absolutely right. appreciate ya i missed that note on the instructionsMake sure you're programming the files for SIMMs 1 and 2 that match the CPU on your security cart. It's probably a Standard CPU judging from your cartridge label.
You mean, it s better to get a no cd game to work with no cd cartridge ultrabios?Ultrasimms works fine with nocd carts.
Thank youIf you are are using ultrasimms then neither is better than the other. The pcbs are exactly the same. Buy the cheapest one that works.
I will go for the cleanest one because last time it was a bad experienceIf you are are using ultrasimms then neither is better than the other. The pcbs are exactly the same. Buy the cheapest one that works.
There is no battery. I though the cd versions had the battery on the mobo, it is not always the case.
Thanks
Yea just go to the first post of this page for instructions as for the files just search for darksoft archive in google is what I didI just received the programmer ,the last hardware piece I needed for the ultra simms setup.Are there any step by step instructions? also where do I get the files I needed? Thanks.
Yep. That’s fine and expected.I finished programming the Ultra Simms, tested all the games and they seem to be running well.However all but one of the Simms failed the SIMM check . Is this normal?![]()
