Glad to hear is working back again! Another happy ending at Arcade-Projects!Shame on me! I format my SD on windows and now it works!
it migh be 1 player. try thatSo I recently got my Batman sound PCB but I can't get Batman to play on this multi.
I get this screen:
My System Assignments are set to 2P and Horzontal, which I'd assume are correct for this game.
This is the only game that's giving me issue other games work. I've tried a handful of other games and they all work.
I've tried a new SD card and I've even tried a different ST-V mobo and the same issue persists
What am I missing?
EDIT: I do actually have the same issue with Find Love on both the old and this new multi. I posted about it a year ago but never got any advice: https://www.arcade-projects.com/thr...-and-trouble-shooting.512/page-20#post-376307
STV Modbios V1.11What BIOS are you using?
WOW thanks for this. The Coin Chute needs to be set to "Common", mine was set to "Individual"Did you set up according to the manual?
Yeah, it was Die Hard Arcade that had the irreverent coin!
Yes, contact @Mitsurugi-ware the batman soundboard still available?
What are your dip switches set to. Put them all back to default and see if that helps?I just got my stv board and dark knight edition. I have everything hooked up but I keep getting a bad cart error. i have taken the board off and tried an original cart and everything works. when i replace the darksoft ot says error and asks me to press service button and it just goes to the sega stv 3d splash screen. has anyone seen this?
I downloaded the stv manual and the jumpers are set to the default. I got in the test menu but didn't see any settings I thought would effect this. any specific setting i should check?What are your dip switches set to. Put them all back to default and see if that helps?
Also press the system/test button and check the settings in there.
Just shotgunning ideas, perhaps someone else’s has most solid steps to a solution.
Not really. Just the cabinet assignment stuff if it’s accessible.I downloaded the stv manual and the jumpers are set to the default. I got in the test menu but didn't see any settings I thought would effect this. any specific setting i should check?
the game loads, i see the board flashing and then it finishes. I can see the status in the lcd and oled screens.Not really. Just the cabinet assignment stuff if it’s accessible.
You have loaded a game right? What happens when you load a game?
