Open Source USB2DB15 for Supergun adapter
Been wanting a case. One that fits on tighter superguns db15 would be a plus. Was what was holding me back from getting one of these.
where do i buy two cases?
You can come to Discord, will be there some for supporters from previous batchs.
Btw, batch 5 is done and ready to be shipped. Thanks of all the supporters.
Pre-order Batch 6 has still some small room.
I think I'm there with the draft cases - I've done these in the same style as the Minigun case, the 4 player adapter, and the SAT2NEO adapter
This is the bottom
Screen Shot 2021-10-28 at 5.59.55 PM.pngScreen Shot 2021-10-28 at 6.00.12 PM.png
And the top
Screen Shot 2021-10-28 at 6.00.23 PM.pngScreen Shot 2021-10-28 at 6.00.41 PM.png
And the reset button - If I've measured it right it shoud sit approx 1/2mm below the surface of the case, so it can still be pressed, but not accidently
The BOM to assemble it would be 4 x M3 20mm Socket head bolts and 4 x M3 nuts
I'll give it another test print tonight and if it comes out OK I will put the STL's in the 3D printing forum
Looks like a tank! :D
I think you can try let the DB15 showing the plate.
Now that you mention it, it DOES look a lot like a tank! The underneath of the top shell has the hatch where the tank commander looks out, and a turret, and the reset button is the cannon. Let me see if I can find a way to leave the DB15 plate exposed.
Hi guys!
USB2DB15 2.0 now have a professionally made shell as well. From batchs 7 and on, the adapter will be shipped alredy enclosed in various color options. If you are part of previous batches and want a case, just check RF projects Discord server for more info.
USB2DB15 Firmware and PCB update. [0.14.13] - 2022-01-12 --Added - Added Support for Generic Zero Delay Controller [Thanks
@s0ckz ] - New PCB and Schematics for Version 1.2 added with some fixes.
Thank you for all your hard work on this project, great to see new features being added all the time.
I've just done a render of the 1.1 and 1.2 boards
1.1 board
1.2 board
I already have several USB2DB15 working on the old hardware (1.1) - are there any major changes that are important enough for me to move to the new hardware (1.2)?
1.1 board
1.2 board
Hi friend, there's just small fixes that won't change any features, you can use the old ones and tell me if find what i changed :p
@hatmoose don't forget to use Ratsnest so you will have the copper pour.
Hello,
I want to buid one adapter with a spare arduino board I have; I've looked at the info on Github but I have a few questions that I couldn't find answers, please help me...
What pins are needed to connect the USB Host to the Arduino? Just the SPI (MISO/MOSI/CLK) and power ? What about SS and INT?
How much power/current (@5v) does the Arduino + USB Host combo need? I'd like to know because while it won't be a problem for SuperGuns, some computers/consoles have limited current capabilities on their control ports.
What kind of Arduino is needed for the project? From the GHub it looks like a 5V-16MHz unit is selected in the IDE, but if it's powered by 3.3V it's running out of spec (2x overclocked).
Thanks.
Hello,
Thanks.
Hi friend,
Did you read the schematics?
