I agree it 100% ok but I would have liked to see the base design credited. Here is the 2 layer board link. I'll look for some of the others but I only accidentally stumbled across themDo you have a link? (It is perfectly fine for them to do this, BTW.)
Yeah I tried both your way and the alternative p1 trying to get to the bottom if it. It appears to only happen on early PGM bases and only when booting first time. DDPDOJ is still in the socketed test board but it works no problem. It's a slightly different problem than the one described as it goes immediately to a black screen with pink text on the left if white (old) is selected first time. Once booted into any other game including black it no longer happens. I had a quick look into what was going on and it appears to be a bios memory clash. I'll try again and it would be great if that fixed it.I dont think you checked all this theard , but if you have time and dont want other crashes to have your customers happy , you can try this too (at least , what i sent out turns out to be just fine and the friend who tried is a good shmups player) :
@PASTBLASTER...Finally built my first cart (DDP DOJ) Everything fired up and plays great! Quick question (Sorry if it's already been covered) When trying to load White Label First, I will get the Cave Date Screen, then an error screen (I have a picture if needed). Rebooting, selecting Black Label (Which everything works 100%) then rebooting and selecting White label, it will then boot and play fine. Is there some sort of memory issue or something else at play?
Thanks so much again for this solution Fluffy, looking forward to making my next carts as soon as my EPRoms show up!
ps : THE DDPDOJ way to be done is only that way i mentioned in that comment .
ALL YOUR PROBLEMS ARE FROM P1 eeprom .
Thanks. At least they provide schematics! The proto area on the prog board didn't seem to have a impact on the cost at JLCPCB, and it gives the option to experiment with extra hardware, like an FPGA for an ASIC implementation, or a USB controller for debugging. IIRC the 4 layers didn't have a huge impact on cost, either.I agree it 100% ok but I would have liked to see the base design credited. Here is the 2 layer board link. I'll look for some of the others but I only accidentally stumbled across them
https://gurudumps.otenko.com/re/index.html
I can see lots of utility in the proto section to experiment. 2 layers added a bit to a 25 board set order I think the 2 layer board was approximately $100 and the 4 layer was $120 (rough figures only). But getting the proto made up for it in my opinion. I didn't really appreciate the boasting about how good he was at routing though.Thanks. At least they provide schematics! The proto area on the prog board didn't seem to have a impact on the cost at JLCPCB, and it gives the option to experiment with extra hardware, like an FPGA for an ASIC implementation, or a USB controller for debugging. IIRC the 4 layers didn't have a huge impact on cost, either.
There is actually quite a big difference, at least from what I've tried with the instant quota - with default settings, 5 pieces of char board was 12.40$, while the prog board is $35.20 (the "board" cost only jumps about 3$, but "engineering fee" goes from 4$ to 24$). This is with default surface finish, with ENIG it's 30.20$ and 52.70$, so I'd say it' quite a difference. Who knows if it's the proto area or 4 layers but maybe it would be worth to experiment with removing it? Maybe JLCPCB caught onto designs with lots of drilling to do or something and now they charge extra?The proto area on the prog board didn't seem to have a impact on the cost at JLCPCB (...) IIRC the 4 layers didn't have a huge impact on cost, either..
Big thanks to @nnap for sending me the bare boards.It depends, on a 5 board order is adds way more percentage wise than a 25 board order at 50 boards its really not much percentage wise at all.There is actually quite a big difference, at least from what I've tried with the instant quota
I think it's the one at the bottom of this page:Has anyone the Dodonpachi dual version binary decrypted ready for being flashed on fluffy's PROG board?
)@Tailsnic Retroworks ... you can try on your setup the file from the mentioned link . its all you need to perfect DDP Dai-ou-jou for your P1 (27c322) position .I think it's the one at the bottom of this page:
https://igspgm.com/engtrans/index.htm
(with the disclaimer that I haven't tried this yet, but I think that's what you're asking about)
Something happens then to my connection in Spainseems to work fine for me.
I'm trying to make it work on sheep_nova's cartridges installing the GAL16V8B logic, but freezes after a few seconds.Does this file only work with Fluffy PCBs or also conversions from genuine carts?
Depends - if you have a genuine cart that doesn't encrypt the M68k code then anything that works with my boards will work with that as well. It looks like the ASIC encryption hardware can be either applied to the M68k code or the ARM code.Does this file only work with Fluffy PCBs or also conversions from genuine carts?
Thanks anyway for the info of the binary @p_ja. I can continue the investigation
Sheep_nova's GAL logic uses A15 input signal of the P1 rom for activating the largest input signals. It's not worth to improveI just tried the latest introless version and most things work great. One problem I am having with it is that the only way I can load White Lable is to go into the test menu. If I don't do this I get this crash. I was having a similar problem with the original ROMs however the earlier version with a menu fixed this problem for me, V3 of the introless is appears to bring it back. Any ideas? I am pretty sure my builds between the 2 versions have remained the same in all other aspects. Nevertheless I love the introless menu.
I got the same crash, mentioned it here:I just tried the latest introless version and most things work great. One problem I am having with it is that the only way I can load White Lable is to go into the test menu. If I don't do this I get this crash. I was having a similar problem with the original ROMs however the earlier version with a menu fixed this problem for me, V3 of the introless is appears to bring it back. Any ideas? I am pretty sure my builds between the 2 versions have remained the same in all other aspects. Nevertheless I love the introless menu.
So, I tried this version today and it seems similarly fussy about the initial NVRAM state as the version that was used before the iq_132 patch - on my first try it crashes right after copyright screen on both version A and version B (version A with a weird error misaligned by half a screen, version B with the ADDRESS ERROR and a more normal looking error...I have the honor of announce you a definitive fixed version of DDP DOJ Black Label dual, with DDP original bios for avoiding the IGS PGM boot-up animation and datetime table. It boots directly on the selection screen.
