he's trying to use 27c800 chips for V-Roms on a PROG-GSC board and wants to know the jumper config to do that instead of 27c160s. I'm guessing he said 8mbit instead of 27c800 because he's looking at mask roms.The pinout of the chips should work with 27c160 style EPROMs, which are 2 Megabyte (or 16 Mega-bit), the chip has a switchable 8/16 bit output, and in this case is hardwired for 8-bit mode. (If you look on the schematic it shows a bridge from GND to /BYTE.)
Ok, I wasn't totally sure which 8mbit is going to be used.he's trying to use 27c800 chips for V-Roms on a PROG-GSC board and wants to know the jumper config to do that instead of 27c160s. I'm guessing he said 8mbit instead of 27c800 because he's looking at mask roms.
