cruzlink2
motherfucker!Examining this little board on the 2931 that blew my tube and I see this.....
That looks violent! What Chassis was this? 2931 or 2930?Here's my horror story , this one had fireworks coming out of the yoke
Also, i did raise the idea of the daughter board with Jomac recently, he said he'd heard this theory before but wasn't convinced. He mentioned with these the Flyback fails, causing the voltage to quickly increase which can neck the tube and also damage all manner of electronics from the lightning zapping everywhere
Interesting. My 2931 does that first bit about once every 15 minutes, but it’s in flash and not slowly.An operator in Kyoto showed me a video of one of his MS-2933 models showing some serious HV regulation issues. In the video, the screen would slowly contract to like 3/4 its size (from HV rising) and then snap back to what it should be. Then, after a bit, HV cutoff kicked in, and the screen faded out and grew larger (which is typical in that scenario). I'm not so sure any more the MS-2933 different flyback and driver are necessarily an enormous advantage.
I have this issue on a 2930. It’s been fully serviced too. This issue only comes up on cps1 games. Anything else, no issue. The main offender is Daimakaimura. I’ve tried different pcbs and resolutions and the issue never replicates unless it’s cps1.An operator in Kyoto showed me a video of one of his MS-2933 models showing some serious HV regulation issues. In the video, the screen would slowly contract to like 3/4 its size (from HV rising) and then snap back to what it should be. Then, after a bit, HV cutoff kicked in, and the screen faded out and grew larger (which is typical in that scenario). I'm not so sure any more the MS-2933 different flyback and driver are necessarily an enormous advantage.
I’m not sure where to start looking since it’s so random; these chassis are a real bastard to troubleshoot. I’ll pull it this weekend and see if I can find anything out of the ordinary.Shrinking is risky business. That means a rise in high voltage, which is alarming because the conclusion is unpleasant.
you changed both caps? 22uf and the 2.2uf?Yea, I was pretty nervous. Still am honestly, after it cracked my tube i feel like I'm playing Russian roulette every time i turn on my blast cities
This happen to me with an MS2931. While playing mushi futari stage 3, the monitor would click turn off and turn back on during a specific spot in the stage. Picture size changed from big to normal. The Chassis did not go into HV shutdown and tube turnt off. I immediately turned the cab off after hearing some weird noises. All went silent and all of a sudden, I could hear a heez coming from the back of the cab. Took the service door off and I could see the yoke slightly leaning. I was super upset. It was game over. Sent the Chassis to Las Vegas and it was confirmed that the flyback was bad. It was the stuff of nightmares. Chassis was fully serviced, video proof was sent to me that the chassis is working but now I have some PTSD from the experience. Just sharing.Here's my horror story , this one had fireworks coming out of the yoke
