GeorgeSpinner
Coin worked in service menu on my Retail Rastan. It also works fine in the MiSTer core.Too bad that we not have another bootleg to test. To verify if the behavior is same or if it's just your bootleg that behave strange.
Since the coin inputs work with the earlier revision on the bootleg it should be possible to fix it for this revision but more information is needed to be able do to so.
Another problem is that we can't trust Mame to 100%. The coin inputs does not work in service mode in Mame, but I asked someone to try this on their Rastan Saga and on his PCB did the coin input work. So I suspect something is wrong in Mame. That is very strange. But I have tested som other game and they had the same problems. For example "Armed Police Batrider" and some other Taito games. from the same period as Rastan.
I believe the MiSTer core is actually based on the bootleg PCB. Jotego often fixes design flaws, so it may not be an exact clone. I'll try to look into it further.
I suspect most bootleg Rastan will perform the same. The repair logs I've seen have all looked just like mine. I'm guessing they behave similarly.
I understand that it's not really a fix, and is more of a work around, but I have put a lot of time, effort, and money into the PCB and it's nice to finally be able to enjoy it
Thanks again.
