Tailsnic Retroworks
That issue was hitting me, when I thought it. You have read my mind. I'll try to figure it outNice work.
It looks like you have the Q-15 dip pin connected to both 244s. I suspect you might run into issues when you are in 8bit mode. Specifically in that mode Q-15 from the dip will be an address signal coming from the MVS going to one of the LVC244s, but when the HCT244 that is also connected to that trace is enabled its going output a signal and cause a conflict. So I think you need another jumper that picks if the Q-15 dip is connect to the HCT244 or LVC244. I guess another possibility might be for the high byte HCT244 to never be enabled in 8 bit mode?
