J
jassin000
250$ for ANYTHING AES is still a "deal" heh.250 lololololo
This, 250€ is a solid price. Especially since its using all new snaplocks, case shells and PCBs. In fact it would be more expensive and time consuming to make one yourself. Not only are you having to deal with 64Mb C roms, but good luck finding a PCM2 sack cart for less than 250€Seriously, I don't know how you think you'll make anything even close to that nice for significantly less than that. And that's not even taking into account the opportunity cost of your time invested.
Atomikwave will release MVS carts but without stickers nor artwork... shell + pcb + eeprom and basta for something like 100€ if i remember correctly...what about a mvs cart. I have a 6 slot i would like to play it on.
After playing the game a bit and comparing it to samsh5sp, getting the same story sequence looped after each match is clearly "abnormal".I noticed the same thing using FBNeo with second P1 crc 70DE1BF5... And no, i don't think it is normal.Is it normal getting story sequence "... His Majesty..." after each match with 8 MB P1 CRC32 : 70DE1BF5 ; MD5 : 9ff420915a1c9b0a4e2cc425e0769c0e or is it due to the emulator loader I use to play ?
I have also noticed attract mode in US region has no second attract mode loop with the portrait of each character, it may due to the emulator loader as well.
Something has been broken in the second patch code to translate story sequences into English and to make them only available on others regions than Japan.
I will look when I get some free time. Maybe there is another check somewhere that is used to switch strings.I noticed the same thing using FBNeo with second P1 crc 70DE1BF5... And no, i don't think it is normal.Is it normal getting story sequence "... His Majesty..." after each match with 8 MB P1 CRC32 : 70DE1BF5 ; MD5 : 9ff420915a1c9b0a4e2cc425e0769c0e or is it due to the emulator loader I use to play ?
Thanx for your time spent on pbin patch. It's appreciated.I will look when I get some free time. Maybe there is another check somewhere that is used to switch strings.I noticed the same thing using FBNeo with second P1 crc 70DE1BF5... And no, i don't think it is normal.Something has been broken in the second patch code to translate story sequences into English and to make them only available on others regions than Japan.Is it normal getting story sequence "... His Majesty..." after each match with 8 MB P1 CRC32 : 70DE1BF5 ; MD5 : 9ff420915a1c9b0a4e2cc425e0769c0e or is it due to the emulator loader I use to play ?
0x10A56
0x10B1C
0x105FE
0x11232
0x3817A
0x3775A
0x3775E
0x1145C
0x112F2
0x10BDE
0x10F2C
0x10F6E
0x1117C
0x11212
0x11390
0x94F0
0x3803C
0x38028
0x10624
0x10938
0x68C8
0x10A80
0x11330
0x17DBE
0x1826E
0x25342
0x9534
0xEB6C
0x8A744
0x5044A
0x926FA
0x54FAC
0x95246
use the same top file than samsho5 special uses.i will try, how i can generate the fpga file? @Darksoft
Tested, it works!use the same top file than samsho5 special uses.i will try, how i can generate the fpga file? @Darksoft
If you do this manual edit on the patched p1 rom it should stop the extra storyI will look when I get some free time. Maybe there is another check somewhere that is used to switch strings.I noticed the same thing using FBNeo with second P1 crc 70DE1BF5... And no, i don't think it is normal.Something has been broken in the second patch code to translate story sequences into English and to make them only available on others regions than Japan.Is it normal getting story sequence "... His Majesty..." after each match with 8 MB P1 CRC32 : 70DE1BF5 ; MD5 : 9ff420915a1c9b0a4e2cc425e0769c0e or is it due to the emulator loader I use to play ?
me not, I'd like to know more about physical source/origin of these game data.Honnestly i'm fully satisfied to have access to "original" 2004 Samurai Showdon V Special location test datas (i don't think original ROM was decrypted. probably made for Samurai Shodown Neo Geo Collection).
here is the thing - these patches is not by SNK, it is made by 3rd-party contractor.But i want to thanks all people who spent time working on run-time pacthes by SNK to make this Samurai Shodown V Perfect.
That's what I have. Im playing on hardware, and the 1st cut scene seems to loop after every battle.After playing the game a bit and comparing it to samsh5sp, getting the same story sequence looped after each match is clearly "abnormal".
Ok, gonna try to replace data at 0x10a7a with a No OPeration patch and let you know.If you do this manual edit on the patched p1 rom it should stop the extra storyI will look when I get some free time. Maybe there is another check somewhere that is used to switch strings.I noticed the same thing using FBNeo with second P1 crc 70DE1BF5... And no, i don't think it is normal.Something has been broken in the second patch code to translate story sequences into English and to make them only available on others regions than Japan.Is it normal getting story sequence "... His Majesty..." after each match with 8 MB P1 CRC32 : 70DE1BF5 ; MD5 : 9ff420915a1c9b0a4e2cc425e0769c0e or is it due to the emulator loader I use to play ?
at offset 0x10a7a you should see 0E6020011A603066, change it to 714E714E714E714E
However, I'm pretty positive there are going to be other issues further into the story sequence. Its getting beyond my skill set / free time to be able to track them all down. It maybe best to use the original patch and/or have someone else take a look.
Someone wanna give this a try, do the above edit and also this one to the patched p1 romIf you do this manual edit on the patched p1 rom it should stop the extra story
Thanx again. As expected, it worked fine, the 1st story sequence is no longer looped after each battle and no more issue with 2nd attract mode loop.If you do this manual edit on the patched p1 rom it should stop the extra storyI will look when I get some free time. Maybe there is another check somewhere that is used to switch strings.I noticed the same thing using FBNeo with second P1 crc 70DE1BF5... And no, i don't think it is normal.Something has been broken in the second patch code to translate story sequences into English and to make them only available on others regions than Japan.Is it normal getting story sequence "... His Majesty..." after each match with 8 MB P1 CRC32 : 70DE1BF5 ; MD5 : 9ff420915a1c9b0a4e2cc425e0769c0e or is it due to the emulator loader I use to play ?
At 0x1132C, I can see 2D4A15602A66 with your preview patched P1 rom CRC32 796DDC04 ; MD5 291181C777FC93FDA84CF6BE1F628E90.Someone wanna give this a try, do the above edit and also this one to the patched p1 romIf you do this manual edit on the patched p1 rom it should stop the extra story
at offset 0x1132c you should see 2D4A15604866, change it to 714E714E714E
This should at least fix the missing story bits at the end of the 3rd/6th stage.
