Frank_fjs
Multi Boyz 4 Lyfe
Multi Boyz
Australia - Adelaide
I can't wait for them to arrive! Hopefully it all works well, I spent heaps of time on it.
It's quite a nice clean design I think, easy access to connections. Being 4 layer means all power, audio, video and controls have their own layer which eliminates interference between signals.
I'll probably still produce the previous design as testing has gone extremely well and it's a lot cheaper to produce.
Latin00032
New User
Totowa
if this supports neogeo and saturn controllers how much input lag would they introduce to the system as a whole?
djsheep
Multi Boyz Overlord
Multi Boyz
Brisbane, Australia
Neo Geo sticks & pads have zero lag, same with SNES and Mega Drive controllers.
Still awaiting a Saturn controller adapter and @undamned adapters, but I assume there won't be any lag with those either.
xodaraP
Gold Coast, Australia
I'm using a UD-USB and can confirm there's no lag. Using a Qanba Q4RAF with a Brook Universal Fighting Board
USA
It sounds like the new design isn't quite available yet. Any ETA on those?
I'd love to get ahold of something in the meantime. Anything available now? Old design, b-stock, etc.
Frank_fjs
Multi Boyz 4 Lyfe
Multi Boyz
Might be able to sort something out for you, give me a few days.
randomdoohickey
Valley of the Sun
I'm not sure a 24 pin will fit on the newer design though due to relocation of connectors. The ATX connector is on the left hand side now, with 2 x controller ports on the front edge and kick harness, video/audio, RGB trimmers on the right. Composite video is available from the main supergun pcb with the options of a 3/4 player controller hat and s-video/3.5mm audio jack hats.
Given the direction the PC power supply world is going, I'd seriously think about tweaking the design to use a 24-pin ATX connector on the board. I've already run across a number of newer PSUs that are fixed 24-pin without the 20+4 split connector.
Frank_fjs
Multi Boyz 4 Lyfe
Multi Boyz
Definitely want to support the 24 pin connectors. Still waiting for the new layout PCBs to arrive then I'll see where we are at.
Not much I can really do if a 24 pin doesn't fit but I'll try and work something out. There are still plenty of split pin ATX supplies available as well as 24 to 20 pin adapter cables, in a worst case scenario.
Frank_fjs
Multi Boyz 4 Lyfe
Multi Boyz
So the prototypes are in transit and should reach me this week. Will test, sort out any issues if need be and make sure everything is running as expected. Next step will be ordering the finalised pcb design, waiting for them to arrive, assembly, then shipping!
I'd suggest a timeline of 6 weeks from today all going well. I know it's been a long wait but I need to get everything perfect before I'm willing to release. Of course this is assuming there aren't any major issues with the new design, which is drastically different to the previous version.
beast1x5
Brooklyn New York
EXCITEMENT!!!!!!!!!
fstrike
Winnipeg, MB Canada
I'm just waiting patiently for the final design to be released lol
