jermz1
What revision is it?
Rev 1.15.1 = 4.20What revision is it?
hello i have a namco es3 that does not start anymore is it possible to change HD? thanksHo realizzato un Tekken 7 multi di base. Spero solo che il Round 2 venga rilasciato presto e che la vita sia completa.
Per coloro che mi hanno PM'd, ho intenzione di rilasciare questo alla fine. In pratica ho corretto la protezione del dongle dal codice di gioco, con alcune altre modifiche qua e là per renderlo possibile. Il mio obiettivo è la minima modifica ai binari per scopi di conservazione. È pensato per essere utilizzato su un ES3X originale e puoi comunque collegare due unità se esegui la stessa versione su due sistemi.
A tale proposito, se a qualcuno capita di imbattersi in un dump del Round 2, per favore inviami un messaggio perché posso fare lo stesso con quello.
There is one caveat unfortunately though. Unless you have the original correct dongles, you’ll have to figure out how to patch them out. That’s all the info I’m giving out…I can't provide any links to pirated material or discuss it further as this is against forum rules, but if you google the thin "emu line" you should really be able to find what you need.
True, as much as I wish to talk about some awesome software solutions, I unfortunately can’t due to forum rules, which I highly respect. The hardware/games are too “new” and are still being sold/played in arcades. I’m still kinda wondering how his disk got bitlocker triggered if he only changed the CMOS batteryThis hobby is like most others these days, before we needed to know how to solder, now it's all TPM and Bitlocker.
Otherwise it's a bit of a paperweight/doorstop, and we can play the waiting game for a decent exploit/zero day and see how that goes.
Like when shellshock arrived and we could all gain entry to the Lindberghs
I'm assuming his disk is just broken, and he has dongle(s) to use though, i didn't read the whole topic lol..
I do not even know how you know it was possible I see that there is no wayÈ vero, per quanto desidero parlare di alcune fantastiche soluzioni software, sfortunatamente non posso a causa delle regole del forum, che rispetto molto. L'hardware/giochi sono troppo "nuovi" e vengono ancora venduti/giocati nelle sale giochi. Mi chiedo ancora come sia stato attivato il bitlocker del suo disco se ha cambiato solo la batteria CMOS![]()
