xodaraP
Replace the F PAL with a G PAL, rev 6 like rev 7 doesn't need the jumper.
I have two Boards. One a dead COTA and one a Phoenixed MvC. CoTA has F pal plus wire, MvC has G Pal.Replace the F PAL with a G PAL, rev 6 like rev 7 doesn't need the jumper.
https://cps2.avalaunch.net/I'm trying to see if its worth repairing a copy of X-Men: COTA I picked up as bad, it appears to be "X-Men: Children of the Atom (USA 950105)" but I can't find a phoenixed or decrypted version of the build to burn and test with are there any other options? Can I used the Euro version? Thats the only version I can find a Phoenix build for.
Does anyone here know where I can get this?Has anyone converted the SIMM data of the CPS2 Puzz Loop 2 daughter board into regular bin data format to burn onto EPROMs for direct use on the main board?
I know this was done with other CPS2 games, like Pro Gear, but am unable to find out if it’s been done for Puzz Loop 2.
I suspect that my Puzz Loop 2 daughter board has failed, and would like to use EPROMs directly on the main board to confirm this.
I have the same issue, did you re burn x2 the same eeprom or used new?Man. This is crazy, but rom 11 is the problem. I verified it after burning, but it must have been a bad burn. I burned 2 of them, and they were both bad. Thanks to everyone for helping me rule things out. Learned about jedec vs non jedec roms as well...
I reloaded the rom file (rom 11) and used a different eeprom. Make sure your software is set to accept the specific rom before loading rom 11 or if will truncate the fileI have the same issue, did you re burn x2 the same eeprom or used new?Man. This is crazy, but rom 11 is the problem. I verified it after burning, but it must have been a bad burn. I burned 2 of them, and they were both bad. Thanks to everyone for helping me rule things out. Learned about jedec vs non jedec roms as well...
Finally I found. I have a rev 4 so I must solder a wire from pal to C13/C3.I reloaded the rom file (rom 11) and used a different eeprom. Make sure your software is set to accept the specific rom before loading rom 11 or if will truncate the fil
