So I got an Irritating Maze Cart/interface PCB and I was really interested in how to hook up an air compressor and trackball. Spent some time with the wiring diagram to trace out everything so I've got a pinout for the interface PCB... figured I'd share here for anyone else that might be interested:
Interface PCB JAMMA
01-GND
-A-GND
02-GND
-B-GND
03-+5V
-C-+5V
04-+5V
-D-+5V
05-N/C
-E-N/C
06-+12V
-F-+12V
07-KEY
-H-KEY
08-Coin Counter 1
-J-Coin Counter 2
09-N/C
-K-N/C
10-Speaker(+)
-L-Speaker(-)
11-N/C
-M-N/C
12-Video RED
-N-Video GREEN
13-Video BLUE
-P-Video SYNC
14-Video GND
-R-Service Switch
15-Test Switch
-S-N/C
16-P1 Coin
-T-P2 Coin
17-P1 Start
-U-N/C [P2 Start]
18-Card Dispenser Vend Switch NO (Card reader pin 4) [P1 Up]
-V-Trackball X-A (XPCB Pin 1) [P2 Up]
19-N/C [P1 Down]
-W-Trackball X-B (XPCB Pin 4) [P2 Down]
20-Card Dispenser Vend Ready Signal (Card reader pin 5) [P1 Left]
-X-Trackball Y-A (YPCB Pin 1) [P2 Left]
21-Card Dispenser Jammed Signal (Card reader pin 9) [P1 Right]
-Y-Trackball Y-B (YPCB Pin 4) [P2 Right]
22-Card Dispenser Empty Signal (Card reader pin 11) [P1 SW1]
-Z-Left A Button [P2 SW1]
23-N/C [P1 SW2]
-a-Left B Button [P2 SW2]
24-N/C [P1 SW3]
-b-Right A Button [P2 SW3]
25-N/C [P1 SW4]
-c-Right B Button [P2 SW4]
26-N/C
-d-N/C
27-GND
-e-GND
28-GND
-f-GND
Interface PCB CON2
(these outputs are controlled by transistors on the interface pcb)
The "Timer Lamps" are the ten small lamps along the bottom of the marquee
01-46AT- Timer Lamp R5
02-47AR- Timer Lamp R4
03-48AD- Timer Lamp R3
04-49AY- Timer Lamp R2
05-50AG- Timer Lamp R1
06-51AB- Timer Lamp L5
07-52AV- Timer Lamp L4
08-53AH- Timer Lamp L3
09-54AS- Timer Lamp L2
10-55AK- Timer Lamp L1
11-56AM- TrackBall Lamp
12-N/C
13-N/C
14-N/C
15-N/C
16-N/C
17-N/C
18-N/C
CON3
(24V power input)
01-15EP- +24V From PSU
02-13NK- GND from PSU
CON4
(Output to relay PCB)
01-66AT- Relay Board Pin9 (SSR8 coil-) (not used)
02-67AP- Relay Board Pin8 (SSR7 coil-) (not used)
03-68AD- Relay Board Pin7 (SSR6 coil-) (Air Compressor Activate) (output to an additional separate relay)
04-69AY- Relay Board Pin6 (SSR5 coil-) (Air Valve Activate)
05-70AG- Relay Board Pin5 (SSR4 coil-) (Left and Right Side Lamps)
06-71AB- Relay Board Pin4 (SSR3 coil-) (Color Lamp 2 behind marquee)
07-72AY- Relay Board Pin3 (SSR2 coil-) (Color Lamp 1 behind marquee)
08-73AH- Relay Board Pin2 (SSR1 coil-) (Flash Lamps) (output to 2 additional separate relays there are 4 flash lamps total)
09-74AS- Relay Board Pin1 (coil+ for all SSRs)
Interface PCB JAMMA
01-GND
-A-GND
02-GND
-B-GND
03-+5V
-C-+5V
04-+5V
-D-+5V
05-N/C
-E-N/C
06-+12V
-F-+12V
07-KEY
-H-KEY
08-Coin Counter 1
-J-Coin Counter 2
09-N/C
-K-N/C
10-Speaker(+)
-L-Speaker(-)
11-N/C
-M-N/C
12-Video RED
-N-Video GREEN
13-Video BLUE
-P-Video SYNC
14-Video GND
-R-Service Switch
15-Test Switch
-S-N/C
16-P1 Coin
-T-P2 Coin
17-P1 Start
-U-N/C [P2 Start]
19-N/C [P1 Down]
23-N/C [P1 SW2]
24-N/C [P1 SW3]
25-N/C [P1 SW4]
26-N/C
-d-N/C
27-GND
-e-GND
28-GND
-f-GND
Interface PCB CON2
12-N/C
13-N/C
14-N/C
15-N/C
16-N/C
17-N/C
18-N/C
CON3
(24V power input)
CON4
