The Spaniard
Thing is, if my memory is correct my board is a rev 7 and I didn't need to cut any traces.
Cheers, I guess it depends on the game the board was used for? mine was SFZ.Thing is, if my memory is correct my board is a rev 7 and I didn't need to cut any traces.
Thanks for the reply, now that the jumpers are ruled out, here's the full story:Solid green screen is not related to jumpers, must be something else. I assume that you read the instructions, right? Make sure that the PCBs sit properly, specially the tiny one that interconnects both. Also make sure that you discharge the 3-leg condensor (EXC5 IIRC) just behind where the battery was placed.
Last but not least, make sure that you are using the right romset depending on whether you installed the key writing wires or not.
Did you actually fully remove the battery from the board, Because in those pics it is still on the board. I you have not you will need to remove the batt and then short pins of EXC5 to discharge board.Thanks for the reply, now that the jumpers are ruled out, here's the full story:Solid green screen is not related to jumpers, must be something else. I assume that you read the instructions, right? Make sure that the PCBs sit properly, specially the tiny one that interconnects both. Also make sure that you discharge the 3-leg condensor (EXC5 IIRC) just behind where the battery was placed.
I am using a fully working Japanese (green) SF Zero board, Rev7
I have installled the 4 programming wires, (see pics)
using "CPS2 Roll-Up Base Pack 2018-04-26.7z"
Board had a PAL E, purchased and installed a PAL G from "saveyourgames". I tried putting back the original PAL E to see if i was getting grabbled graphics, but the results were the same.
While installing the kit I broke one of the flimsy pins of the main board. I soldered a jumper wire, tested continuity successfully, no shorts on nearby pins.
I initially installed the interconnect backwards but put it back the right way after reading this thread.
I have reseated the board multiple times and ensured there's a tight fit.
I tried 3 diff SD cards : Sandisk 16gb, Samsung 32gb, Nokia 1gb.
I formatted FAT32 using both windows format tool and the SD formatter utility.
I tried both extracting the roms directly to the card and copying the extracted roms in one copy/paste command
I have ordered a 4GB Transcend card from ebay, will try that too
I have shorted all 3 pins of EXC5 for over 10 seconds multiple times to no avail.
Here are some pictures
https://imgur.com/zsH5p89 https://imgur.com/ILET3rF https://imgur.com/qrWHLD5 https://imgur.com/47x0VD4 https://imgur.com/I3c6BGE https://imgur.com/pk5jeRn https://imgur.com/cs2BukY https://imgur.com/09Etklf https://imgur.com/1vlk9F3 https://imgur.com/hm15jNi
Running out of ideas here guys
Totally what @DarthMig said.
But he says he does have the 4 wires installed, so he is using the correct roll up pack.
But I second removing the battery and shorting EXC5
Thanks guys, I had specifically asked if removinng the battery was strictly necessary but was previously told that it wasn't hence why I didn't:Did you actually fully remove the battery from the board, Because in those pics it is still on the board. I you have not you will need to remove the batt and then short pins of EXC5 to discharge board.
cheers for the reply.Would a bad G PAL cause the problems he’s having? I know sometimes those replacement PALs don’t always program properly.
Even though you installed the 4 wires, it would be a good test to use the ‘old’ decrypted roms, just to rule out some thingsHey,@djcalle ... This (CPS2 Roll-Up FULL MAME Add-On Pack 2017-11-19.7z) is what you must use on your sd card ... extract that folder on your computer hdd after you give an format fat32 to your 16gb sd card (sandisk should be ok) and then copy that folder "games" to your sd card (over 10 gb i think it's the final extracted files). Cheers!
Cheers Pascal, Check my last post just before yoursEven though you installed the 4 wires, it would be a good test to use the ‘old’ decrypted roms, just to rule out some things![]()
He posted links to pics on post 284.Have you posted pictures of your pcbs for us yet?
https://www.arcade-projects.com/forums/index.php...Have you posted pictures of your pcbs for us yet?
