Why not just plug in a mouse and keyboard to the TTX3 and make your changes on the live PC?How do you test this on a laptop, I’m removing hard drive every time I make a change, then plugging back in to arcade machine to test, it’s easier to make changes on the laptop.
I have all my files and downloads on my laptop, so if i want to change something or add anything then it's easier to do on the laptop. I do have a mouse and keyboard plugged in to test other things.Why not just plug in a mouse and keyboard to the TTX3 and make your changes on the live PC?
What controls are you using? Fastio or keyboard? Did you change any button mapping in demul? Did you change the default a3x?I don't know why but i can't give up on getting cvs2 working, it runs fine but no controls, however if i go into explorer and open it through demul it runs fine with all controls working, does anyone have any ideas so i can get it working and move on to something else.
The a3x script loads fastio.exe in the demul folder to set keys. Should be the same for all games. I don’t have fastio to test yet though.General Question on Control Configuration in Emulators (Demul)
So I use a Vewlix Control Panel connected via Fast IO.
Most games work fine but especially the new added NAOMI Games don't work without keyboard.
How exactly do I need to set Controls?
From what I understand you would need to set controls in Demul once and this would apply to all games using Demul e.g. Naomi, correct?
So why do some Noami games work and some don't?
Additionally, there is Demul07_280418 and Demul07_280418-ANALOQUE - What's the difference?
To make it short: How do I set controls on Demul for Naomi/ Naomi 2?
well that could be the key since I downloaded the changed „no nag screen a3x“ scripts… however the most games are working thoughThe a3x script loads fastio.exe in the demul folder to set keys
You should try to decompile one to check what’s in it, or post one that is having an issue to see if there is a typo in there or something.well that could be the key since I downloaded the changed „no nag screen a3x“ scripts… however the most games are working though
I'm using fastio, i changed both demul to the same for controls, and if i run it direct from demul it works perfectly, i havn't looked at the a3x as havn't looked into those yet so don't know what i'm doing there.What controls are you using? Fastio or keyboard? Did you change any button mapping in demul? Did you change the default a3x?
I don't know how to check this, sorryAre the keyboard keys for one that is working the same as one that isn’t working?
That should be the one. And HIGHLY APPRECIATED THAT YOU DO THIS!It’s missing the fastio line. Is there a thread link with all the naomi a3x files, I can edit them and put them back in for you. I see one link with 10 only.
Had a couple minor issues with these zip files, but they seem to be okay now. If any problems pop up with any of these scripts, please let me know.
I can test tomorrow. thanksGive these a try. Just recompiled from the original 10? plus pstone that you linked.
See, this person did all the work already lol. Making me do work for no reason. Just DL his pack.Dl my pack you have all Naomi un au3 and 3ax and you can édit it and you can see all you need
