thomas3184
Also may I ask what you used to compress this down to 36KB?Dl my pack you have all Naomi un au3 and 3ax and you can édit it and you can see all you need
Sorry I must have missed that one. Hard to keep track.See, this person did all the work already lol. Making me do work for no reason. Just DL his pack.
@djvautrien MerciGuys,
I created my Naomi from rom included inside with fastio support, and I added projet justice from original pack,
I share au3 and a3x inside my pack if someone see missing games can tell me.
and correcting Naomi error
If $fe Then
FileChangeDir("E:\system\AM")
Run("E:\system\AM\Multi.exe")
Regards
You welcome, maybe some game missing I don't really. know but you can use another and just change rom name for new game.Sorry I must have missed that one. Hard to keep track.
Here is the Link to his post:
@djvautrien Merci
Thanks for that i've just tried cvs2 and powerstone and both work, the ones djvautrien had put on are the ones i used previously as it had the full list so must be an issue with cvs2 in his zip, but it's all working now so i'm greatful to everyone.Give these a try. Just recompiled from the original 10? plus pstone that you linked.
Weird, maybe files got mixed up with another download since there were so many flying around. I checked dj’s and cvs2 looks good in there.Thanks for that i've just tried cvs2 and powerstone and both work, the ones djvautrien had put on are the ones i used previously as it had the full list so must be an issue with cvs2 in his zip, but it's all working now so i'm greatful to everyone.
Are some of those games just hard coded? If you figure it out, let me know.Hey guys, Caladrius AC under RING runs at 1280 X 720. Is there an easy way to change it to run at 1920 X 1080?
While I agree here with you, the majority of people are “purists” and want the arcade version with the ability to use coins/tokens and their cab I/Os. I say “purist”, because even though this multi is using loaders just like anyone else running it on a general PC, they see it as an authentic arcade experience because they are playing it from a Taito branded PC.I wonder if it wouldn't be better to replace all games that have PC ports with their ports. Like Caladrius Blaze instead of Caladrius AC, and 2 player PC version of SFV instead of 1 player arcade version
Then again, the PC version is not always better, according to reviews (still 720p) https://www.gog.com/en/game/caladrius_blaze
Seems the PS4 is the only version that runs at 1080pAre some of those games just hard coded? If you figure it out, let me know.
I'm assuming trying to run it using Teknoparrot wont make a difference?Are some of those games just hard coded? If you figure it out, let me know.
So I have tried these and also the ones from @djvautrienGive these a try. Just recompiled from the original 10? plus pstone that you linked.
only settings i changed were in arcade joy 1 and joy 2, i did the same with both demul and demul analogue as wasn't sure which to use, i used the last ones thomas put up and worked perfect.So I have tried these and also the ones from @djvautrien
none of the Arcade Control work, also on the games that worked previously.
So I think I messed something up when I was trying to set up Controls in Demul.
Anyone know how to reset or properly configure demul?
Or any other suggestion what I can do. I am about to rewrite my image from scratch....
This is how Demul looks and the only thing I tried was to set controls for Arcade.
HDDRawCopy works well and is pretty easy to use, and free.Now i've done some changes on this i'd like to backup my drive before doing more, what does everyone suggest using to create there disk image, windows 11 is doing my nut in finding anything
Cheers, I tried that earlier but when selecting backup drive for target it was going to delete everything, just had another look and I’m supposed to select file and destination folder, doh , it’s been a while since I used it lol, but working now thanks.HDDRawCopy works well and is pretty easy to use, and free.
Well you hit the nail on the head earlier, that is seen as a game by Attract Mode so you need to use another method for launching a game automatically or shutting down the system. I've used the Utility Menu plugin for Attract Mode before which probably wouldn't have the same issue. It's quite cool because you can run anything as a script so it's pretty versatile. Actually, doesn't Attract Mode have an option to shut down the system on exit? you could use the standard tab menu exit command in AM.
In terms of the explorer issue - why are you going into explorer every time? it's only there for making changes right? if you don't launch that explorer link from Attract Mode you won't see a start menu, task bar and icons. It's just how Windows works, not sure if you can change it but it shouldn't be an issue in regular use.
