The 1060 is 8-10% more powerful than the 1650, either will card chew through all these arcade fighters, get whatever fits the budget. The GPU world is still screwy, so anything decent is still overpriced.Now your just putting a spanner in the works, the 1060 has 6gb but I’m presuming the 1650 is newer, price wise on eBay there’s not much in it.
Is there any ideal setting for antialiasing and anisotropic?One nice perk of the GTX 1650 is that it has enough excess horsepower that you can crank up the antialiasing and anisotropic filtering in the Nvidia Control Panel. It makes all the 3D games look really nice at 1080p resolution.![]()
It’s a matter of preference and card performance. I always turn off antialiasing on all my games because I like to see the edges of the character models and backgrounds. Having any sort of antialiasing makes everything look to smooth/smeared for my personal preference.Is there any ideal setting for antialiasing and anisotropic?
The higher the better?
I am on a GTX 1060 3GB. It went performed excellent on SFV Benchmark test with everything on max.
or just go as high as possible and check with e.g. SFV Benchmark test?
Guess I just crank up both and check the performance again to find max possible setting?
I am on a GTX 1060 3GB. It performed excellent on SFV Benchmark test with everything on max.
Should I just go as high as possible and check with e.g. SFV Benchmark test?
Yes.Is GTX1060 okay with any manufacturer?
THX.Yes.
You can plug a 4 pin PWM fan connector on to a standard 3 pin without issue, the fan will simply run without PWM function. Why don't you turn off the warning in the BIOS?I bought this Casefan for my TX3 Noctua NF-A15
It's a 4Pin connector and TX3 uses only 3Pin. When I plug it in SYS Fan2 Port of TX3 I get the error message "Your comupter SYSFan2 had problem..." Fan runs fine and after pressing enter it boots into Multi. If I adapt to 3Pin connector does anyone know the wiring?
That’s what I did in the meanwhile. I was worried there‘d be something wrong.Why don't you turn off the warning in the BIOS?
Nice one, was driving me a bit nutty. I'll upgrade Teknoparrot. Do I just choose the option in its menu?I had that too but then I updated teknoparrot for Aleste and it fixed it.
Yeah thats what I did, gives you VF eSports and I think a fair few others too.Nice one, was driving me a bit nutty. I'll upgrade Teknoparrot. Do I just choose the option in its menu?
