Dude, that’s smart. Do you have any stepped pictures on how to go about that?
I removed the control/switch that was installed in the bezel and ran it down to where my old remote board was located.
I did not have this problem with the same screen hmm. Or at least didn’t notice. My biggest problem is access to the menu / power button the first time after installing hehJust chiming in as I recently got a bracket for my Vewlix C and also put in a LG 32GP850-B ($450 on Amazon).
Awesome bracket, not too tough to get aligned. I did need the corner brackets, and I kept the OG glass on it, held with heavy duty electrical tape to the frame, but I don't think it was necessary to keep the glass with this setup.
One thing to note about the LG 32GP850-B: there is a button of sorts on the back of the monitor to release the monitor stand. It's possible to mount the sub bracket to avoid going over the button so it sits flush on the back of the monitor, but when I tried, it wasn't possible to get the screen aligned properly. I had to mount the sub bracket over the button, so it flexes a little over the button, but it seems like it will be fine.
Could you pull out the menu board and extend it to the coin door?I did not have this problem with the same screen hmm. Or at least didn’t notice. My biggest problem is access to the menu / power button the first time after installing heh
I had to do this on mine too; HA said it's to be expected. I did place a felt pad there to ease the strain a little IIRC.Just chiming in as I recently got a bracket for my Vewlix C and also put in a LG 32GP850-B ($450 on Amazon).
considered that too, but didn't want to warranty void for it. It's not so bad with the newer brackets with the cutout.Could you pull out the menu board and extend it to the coin door?
Don’t really see how to do it without removing the monitor chassis fully. It seems like it’s a molded 2 piece chassi.Could you pull out the menu board and extend it to the coin door?
Are you using a Rev A, B or C bracket?Just chiming in as I recently got a bracket for my Vewlix C and also put in a LG 32GP850-B ($450 on Amazon).
LG 32GP850-B
Rev CAre you using a Rev A, B or C bracket?
That would indeed work. But I didn't have anything on hand that I could use as a spacer, and it doesn't seem like a big deal.Easy fix! Spacers!
The Vesa mounting holes in the monitor are pretty recessed.
Put 2 per hole and problem fixed.
Also larger screwsThe Vesa mounting holes in the monitor are pretty recessed.
Would need more like... 7, stacked up and the sub bracket gingerly balanced on top, praying I can slip the screw in all four holes without them getting misaligned
